need help with tire size
whats up classicolds world just had a question about tires size. I have a 72 cutlass supreme and im finally at the part where i need tires i got 15/7 ralleys i want some nice beefy looking size in the back and just a lil smaller in the front with that being said how should i ask for that set up who knows a nice tire set up pics would be nice thanks for reading
more info
Need more info...how do you use your car & what are is the driveline package...engine?...trans?...Rear gear ratio?
I sure would not pick a 275 60 15 tire out back if I had a 350 2bbl with a T350 & a 2.56 open diff.....see my point?
actually, I don't see your point .....
Most probable original tire was G78-14 = ~ 27.1" diameter
275/60/15 = ~ 28.0" diameter
Standard engine in a Cutlas Supreme was a 350 4bbl & 2.73s were the lowest numerical gear in '72 (& yes I understand that many things can be changed in 40 years)
i have a 350 rocket four barrel carb i dont race or nothing well i never drove the car im restoring it but its a 350 th350 tranny stock 10 bolt rearend
Uncle Hulka
Wheels and Tires
April 30th, 2014 04:45 AM
