Click Here
Drag radials and wheels
Old March 1st, 2021, 06:31 AM
Jhucks03's Avatar
What size drag radials and wheels are y’all using. Specifically 68-72 Cutlass.
Jhucks03 is offline
Old March 1st, 2021, 09:19 AM
Rallye469's Avatar
M/T 325 50's
15x10 wheel with 5.5" BS
they're tight but they fit and work well
-peter
Rallye469 is offline
Old March 1st, 2021, 09:45 AM
69455's Avatar
MT ET Street Radial
305 45 R17
69455 is offline
Old March 1st, 2021, 03:44 PM
wills30's Avatar
M/T 325 50's
-peter
can i get a side view of those tire.
i was looking at getting a pair of 315 60 15.
But i have mini tubs
wills30 is offline
Old March 1st, 2021, 07:36 PM
Rallye469's Avatar
Old March 1st, 2021, 07:38 PM
wills30's Avatar
where are you rubbing or hitting
wills30 is offline
Old March 1st, 2021, 08:07 PM
VORTECPRO's Avatar
30x9 C-7 Radial Hoosiers on a 10 inch rim, you can't do better
VORTECPRO is offline
Old March 1st, 2021, 08:42 PM
Chevy budget Olds powered
coppercutlass's Avatar
275/60/15 m/t ss drag radial
coppercutlass is offline
Old March 1st, 2021, 10:11 PM
Rallye469's Avatar
The rub slightly on the inside wheel well.
Usually only when I dont air the back up after going to the track and then drive on the street. (20.5psi)
At normal inflation (26psi) they dont rub.
-peter
Old March 2nd, 2021, 05:43 AM
wills30's Avatar
295
Frank Trimble car.
Haven't seen this in person .
But I've spoken to him .about his set up
wills30 is offline
Old March 2nd, 2021, 06:33 AM
Jhucks03's Avatar
Coppercutlass,
What width wheel? And are there any upgrades to the suspension?
Jhucks03 is offline
Old March 2nd, 2021, 07:47 AM
The wheels are 8 inches wide. From suspension is ebay tubulars tall upper ball joints , 5.5 inches of travel with a limiter 6.75 without , afco 80/20 shocks and Moog 6 cyl chevelle springs. In the rear I have ssm bars , a solid 1 inch sway bar , adjustable uppers , 69 442 rear springs , qa1 single adjustable shocks. Best 60 ft. With my 350 has been 1.56
Old March 2nd, 2021, 03:09 PM
chadman's Avatar
29.5x10.5 MT Pro Bracket Radial on a 15x12 wheel
chadman is offline
Old March 3rd, 2021, 04:17 AM
Out of Line, Everytime😉
olds 307 and 403's Avatar
Some wide tires indeed. What are you guys running for air pressure in the back?
olds 307 and 403 is offline
Old March 3rd, 2021, 06:11 AM
Rallye469's Avatar
25 on the street...20.5 at the track.
Anything less than 19 at the track and the tires start to cup.
-peter
Old March 3rd, 2021, 07:14 AM
chadman's Avatar
I run 18 psi
chadman is offline
Old March 3rd, 2021, 10:12 AM
fleming442's Avatar
Originally Posted by wills30
295
Frank Trimble car.
I've seen it, and it is 100% bada$$! I think he's running 295/65s?
No one has Nitto 555Rs? I guess that says it all, huh? I've been playing with air pressure and launch rpm, but still can't get it to hook for crap.
fleming442 is offline
Old March 3rd, 2021, 12:43 PM
Flemming if you have a stick car perhaps try a bias ply. My mph between slicks and drag radials is the same also I have ran the nittos they work well but if you drive them alot they loose their bite where as the mickey thompson s last longer in that dept.
Old March 3rd, 2021, 03:27 PM
oldsmoboogie's Avatar
I have 295/55 r15 Mickey Thompson drag radials on a 10” wide steel wheel.
oldsmoboogie is offline
Old March 3rd, 2021, 04:31 PM
fleming442's Avatar
I dig it! 😎
Old March 5th, 2021, 04:50 PM
71 OLDS's Avatar
Older pic - with 275/60/15 drag radials:
previous setup: Nitto 305/45/18 Drag Radials (w/glued on BFG RWLs) on 18x10s
current setup = Nitto 305/40/18 drag radials on 18x10s in these pics but soon to be 18x11s:
71 OLDS is offline
Old March 5th, 2021, 05:06 PM
Hey man, those BFG letters are too white to be real!
Koda is offline
Old March 5th, 2021, 05:09 PM
71 OLDS's Avatar
SOS pads!! Keep 'em nice and white!
71 OLDS is offline
Old March 6th, 2021, 05:07 PM
-peter
I can see why you guys run them. I actually ordered the MT drag radials but ET Street Bias ply arrived instead. With any of the bias ply slicks, we were running 8 to 9 psi for best traction at our track. I was running more psi, I followed what the other guys were doing and picked up my 60 ft a bit.
Old March 6th, 2021, 05:40 PM
On marginal prep the bias plys work on 15 is the suspension is there. I run my drag radials at 18 but that's a habit for me I need to bump it up. Oddly enough. My mph and 60 ft is identical between the 2. My suspension was set up for the bias plys . All I do for the radials is that 2 inches of travel out and set the shocks a few clicks up.
Old March 7th, 2021, 05:39 AM
My 88's suspension sucked. The car launched like it was on glass. I was running around 15 psi as well but talking to the other guys with faster cars of various makes, they ran 8 or 9 psi on the airport, which was our track. My 60 ft improved but I did notice slight rubbing on the frame with that low of pressure. If I can get the 3.90 gears and posi in and a wideband in ideally, I want to run it, I miss the track. If Estevan is open, I will try to make it. It isn't just the Pandemic, with oil being down, looking better lately, that City is hurting, was less toys cruising the streets last trip. That will basically leave Saskatoon, 4 hours away, pretty far. I also want to get my 70 to primer as well. Then there is the whole engine build as well.
Tiberian Fiend
October 6th, 2020 12:11 AM
Oldracerjones
Wheels and Tires
June 23rd, 2014 11:14 PM
JasonB
Suspension & Handling
October 9th, 2012 07:06 PM
crash
August 1st, 2011 07:23 PM
Oldsguy
February 2nd, 2008 01:27 PM
Quick Reply: Drag radials and wheels
