56 Olds throttle/jetaway linkage
Old November 20th, 2016, 06:24 PM
cmpcpro's Avatar
Hey guys does anyone have or know of a parts car (56) with a jetaway? My kickdown linkage near the carb is missing some parts and a spring. Basically the kickdown doesn't work because I need these parts. If anyone can help I would greatly appreciate it! Thanks!
cmpcpro is offline
Old November 21st, 2016, 06:11 AM
Tedd Thompson's Avatar
Is the linkage much different than a 54-55 with a slant pan? Years ago (30 or more) I helped a friend put a jetaway in a 55 and I don't remember us changing any linkage. If there isn't any or much you could look for parts that would be easier than a 1/2 year of manufacture..... Tedd
Tedd Thompson is offline
Old November 21st, 2016, 01:56 PM
cmpcpro's Avatar
Thanks I will have to check on that I assume it's different but don't know for sure!
cmpcpro is offline
Old November 21st, 2016, 02:06 PM
lonestarjarhead's Avatar
56 throttle linkage
If it's the same as 55 linkage, I might have it. I would need to check to be sure.
lonestarjarhead is offline
Old November 21st, 2016, 05:23 PM
Phantom Phixer
Charlie Jones's Avatar
By "Jetaway" I assume you are talking about the "Dual Coupling" Hydra -matic that was also used in 57-60 Oldsmobiles. This trans was referred to by Olds in the parts books as a type "O". The type "R" trans is the "slant pan" that was also used in 54 & 55 Models.
I have attached an illustration and several pages from the 1963 Olds Master Parts Book. The illustration is of a 1958 Olds but is typical of a 1956 and the group numbers should be the same. It is the oldest such illustration in the book.
A quick study shows that many of the linkage parts may only fit 1956 Olds with type "O" trans only . But other parts may also fit other models and years .
Good luck on your search.
Charlie Jones is offline
Old November 21st, 2016, 06:32 PM
My concern about a illustration and comparison for a 57 or 58 would be the one inch approximate higher deck height that would or might change the linkage pieces where the 54-55 is working with the same height motor..... Or I could be way over thinking this.... Tedd
Old November 22nd, 2016, 03:09 AM
Frank Ignachuck
ignachuck's Avatar
I'll bet Ozzie will come up with the answer.
ignachuck is offline
Old November 22nd, 2016, 05:55 AM
Phantom Phixer
You're way overthinking this Tedd .
One would use the illustration to find a similar part , and then take the group number (four digit) to the parts list to see the actual years / models that the actual part numbers fit.
In the GM parts system the four digit group numbers describe all parts with a similar function . For example , all water pumps will be in group 1.069 . Illustrations will typically have group numbers .
The parts list has all the groups in order and under that group you would find the year and model and the actual part number.
Old November 22nd, 2016, 07:23 AM
cmpcpro's Avatar
Thank you for the help! Unfortunately I can already see from the photo that the linkage is different than the 56. The kickdown for the O Hydramatic is right in front of the linkage on the carb, not all the way back towards the firewall like in the picture.
cmpcpro is offline
Olds Scott
October 5th, 2015 01:30 PM
real1212
February 5th, 2014 12:32 PM
67townsedan
August 24th, 2013 07:05 PM
MrPorkchops
August 28th, 2012 08:03 AM
Quick Reply: 56 Olds throttle/jetaway linkage
