1954 98 olds PS
Old March 25th, 2016, 08:00 PM
Gene Fettig's Avatar
1954 98 olds PS
Will the complete PS unit from a 1954 Olds. 98 fit into a 1955 Olds. without any modification
Gene Fettig is offline
Old March 26th, 2016, 05:59 AM
Rocketowner's Avatar
I believe everything would be the same. Maybe someone can check it on Hollanders, but I don't think you will run into any problems. Just get the Pittman arm from the one with power steering. I changed one on a '54 Chevy, and had to go back and get the Pittman arm because we're different. Larry
Rocketowner is offline
Old March 26th, 2016, 06:10 AM
1954 98 ps
Thanks Iam Learning
Old March 26th, 2016, 06:52 AM
Ozzie's Avatar
I can't answer accurately because I've never done this, but I can tell you what Hollander says.
They say that '54 and '55 will interchange with the following note:
"Post and worm assembly, cross shaft assembly and housing assembly only. Not sold by manufacturer as a steering assembly."
They also say that the pumps are expected to interchange.
The spindles are the same '53-'56.
Tie rod sockets are the same '39-'60.
The lower arms for '54 & '55 show different part numbers. Interchange is not indicated.
Information on the upper arms for the '54 is not shown in my books.
('55 & '56 interchange)
The knuckle supports for '54 & '55 show different part numbers. Interchange is not indicated.
While I'm unsure about all the implications of the above, such is what's in the Hollander Manual 30th edition.
Ozzie is offline
Old March 26th, 2016, 09:01 AM
Glad Ozzie was able to reach the old Hollander manual. I thought it would be an easy swap.,but I found out again that what "I think and a dollar will usually get you a Coke out of most drink machines ". Larry
Old March 26th, 2016, 09:23 AM
Proud Viet Nam Veteran
redoldsman's Avatar
There is a power steering sector and a pump on sale right now on ebay. They are listed separately but are both from the same seller. The prices are $150 and $75 respectively. That is a really good price on the sector and a fair price on the pump which includes the bracket. You can probably count on having them both rebuilt. Chip at Power Steering Services is the go to person for that. Here are the links:
http://www.ebay.com/itm/1954-Oldsmob...VWSPek&vxp=mtr
http://www.ebay.com/itm/1954-Oldsmob...hWSSEM&vxp=mtr
redoldsman is online now
Old March 26th, 2016, 10:44 AM
1954 98 ps unit
Old March 26th, 2016, 04:22 PM
Ozzie's Avatar
Don't get too discouraged. The steering gear "assembly" in the Hollander can include everything involved in the steering of the vehicle all the way back to (and including) the steering wheel. So when somethings are excluded, they may be things that are not really needed in making the conversion. As the '54 and '55 are similar in many ways sometimes small modifications can get something to work. Best wishes.
Ozzie is offline
Old March 26th, 2016, 05:15 PM
1954 98 Oids.
I sure thank you for the info not sure when you say about small modifications. Thanks again. Geno
jad717
March 24th, 2010 02:05 PM
Kenn55
Cars Wanted
June 21st, 2008 08:16 AM
loveolds
October 28th, 2007 11:01 AM
ozoneblue
July 10th, 2007 10:02 PM
Quick Reply: 1954 98 olds PS
