Where do these wires go? - Installing New Wiring Harness - '55 88
Old April 25th, 2023, 07:00 AM
madmax442.com
madmax442.com's Avatar
My harness grounded out the hot gen wire to a body clip, burned it. I am replacing with the correct factory harness. Finding a couple items not right from the past. The 2 wires (orange/white) pictured where hanging out down by the master cylinder. I ohm'd them out, the are going to the brake switch. I must be going mad, thanks for any help.
madmax442.com is offline
Old April 25th, 2023, 11:06 AM
ub2693v's Avatar
Did it originally have manual brakes? The brake light switch for manual brake cars was under the removeable floor board. Maybe its been upgraded to power brakes?
ub2693v is offline
Old April 25th, 2023, 11:15 AM
madmax442.com
Wouldn't the wiring harness NOT have the gear selection plug in the harness tho? When I went to go buy the new harness, it specifies auto or manual. Yeah, no idea if it was upgraded. I doubt it as it was already a highly optioned car.
The question would be if either manual or auto trans both have the provision for either brake options. That would seem more likely....making more sense now if I can confirm this.
Old April 25th, 2023, 11:23 AM
ub2693v's Avatar
Manual brakes, non vacuum assisted, not manual vs automatic transmission. My parts 88 has manual brakes, are they barrel connectors? The brake switch is screwed directly to the underside of the removeable floor, on power brake cars its inside the car at the top of the brake pedal hinge area, i guess its possible that both styles exist on the same harness?
ub2693v is offline
Old April 25th, 2023, 11:31 AM
madmax442.com
Yep, just confirmed this with Fusick. The only 2 harness are A/C and non-A/C cars, so yes the factory harnesses had provisions for both, that explains it now. Yes they are barrel connectors. So your manual brake 88 has a spare set of orange/white barrel connectors for the power brake sitting unused up under the dash them.
Old April 25th, 2023, 11:37 AM
ub2693v's Avatar
I learn something new every day!!
ub2693v is offline
madmax442.com
May 10th, 2023 06:55 PM
kad36
January 21st, 2017 06:10 AM
kad36
November 27th, 2016 01:35 PM
jo75olds
June 14th, 2011 08:34 PM
mycut
August 25th, 2010 07:49 AM
Quick Reply: Where do these wires go? - Installing New Wiring Harness - '55 88
