55 Fuel Line Fitting
Old August 23rd, 2015, 08:23 PM
Olds Scott's Avatar
When I got my car the previous owner had cut the hard line off back from the bracket on the front cross member that connects to the rubber fuel hose. I need to find out what this fitting looks like. Any one have any pictures of this fitting or know where I can get one?
Olds Scott is offline
Old August 24th, 2015, 07:19 AM
Rocketowner's Avatar
Sorry, I tried to get a picture of the fitting ,but was unable to do so ! Maybe someone has a car with the front end off ,then it would be easy to get a picture.All I could tell it looked like a "L " bracket that the rubber line and hard line connected through. Larry
Rocketowner is offline
Old August 24th, 2015, 08:59 AM
coldwar's Avatar
1953 88 I think the same or close as your '55. There is large flat square
clip the same as is seen on brake line attachment under the bracket which retains the hose to bracket. The fuel line is just a double flare on steel line.
coldwar is offline
Old August 24th, 2015, 11:52 AM
Olds Scott's Avatar
Thanks for the photos Coldwar. Every little bit of information helps.
Old August 24th, 2015, 12:34 PM
That does look just like the one on a '55. I just could not get a picture of it with everything else in the way. Larry
Old August 27th, 2015, 02:03 AM
Andreas.Johansson's Avatar
I got a new rubber hose from Fusick for my 53
Andreas.Johansson is offline
Old September 3rd, 2015, 11:18 PM
74 2.8L Capri
DFitz's Avatar
Yes, that picture is correct for the '55. Too much old grease and road dirt on mine.
DFitz is offline
yamahondarider
June 23rd, 2015 07:34 PM
Del70
November 15th, 2013 02:24 PM
davepnola
December 2nd, 2010 09:00 PM
Flye
July 31st, 2009 04:03 PM
68conv455
May 20th, 2008 02:03 PM
Quick Reply: 55 Fuel Line Fitting
