1955 Olds hydramatic shift lever grommet
Old May 8th, 2017, 06:52 AM
Olds Scott's Avatar
The grommet on my hydramatic transmission shift lever has deteriorated and needs replacing. Where can I buy this piece? Thought about adapting a nylon bushing for the purpose,
Olds Scott is offline
Old May 8th, 2017, 05:18 PM
Tedd Thompson's Avatar
I'm not sure of the grommet you are speaking of a picture would be nice. Have you contacted Fatso automatic transmissions they may have what you need.... Tedd
http://www.fatsco.net/
Tedd Thompson is offline
Old May 9th, 2017, 02:41 AM
Ozzie's Avatar
If it's the one on the lower lever near the bottom of the steering column, the group is 4.042 and the part number is 563843. (Used 1951-1956). I don't know where to get one. Tedd's suggestion might be a good place to start. The nylon bushing might be a good idea if you can find a substitute or fabricate one if you're handy in the machine shop. This place has some:
https://www.mcmaster.com/
Ozzie is offline
Old May 22nd, 2017, 09:27 AM
Olds Scott's Avatar
Went to the hardware store and bought nylon piece and adapted it to the trans shifter arm and it works great. Thanks Ozzie
Olds Scott
December 18th, 2016 04:06 PM
Rocketbrian
October 2nd, 2013 10:18 AM
dmberendsen
April 10th, 2013 03:18 PM
gsnorris
July 25th, 2012 03:08 PM
Flye
April 18th, 2011 04:24 PM
Quick Reply: 1955 Olds hydramatic shift lever grommet
