Unnecessary cruise control parts?
My car has no cruise control switches or turn signal lever cruise buttons in the interior, but under the hood there is a box marked “Dana/Perfect Circle” where the speedo cable goes into, with a second cable down to the trans. The box also has several electrical connections, but no vacuum hoses connected (as in circled pic).
So why is this box there, and could the fact that the vacuum hoses are missing add to my other apparent vacuum issues?
Scott
Has this control unit
But no switches or buttons
Not here either
Missing these vacuum connections
Scott
Not here either
Well, either someone was intending to retrofit cruise and never finished it, or the dash and steering column have been replaced, or at some point in the past the inner fender was replaced with one from a cruise control car. A lot can happen in half a century.
Scott
For some reason I was thinking 68 A-body used the AC vacuum transducer CC? rather than the Perfect Circle unit?
To eliminate it you'll need a non-CC speedo cable. No adapter needed. Screws on at transmission end, clips on at speedo. You have to go into the dash for that lighting issue anyway; do it all at once. On a 68, that is important!😬
There's market for these things so don't toss it. Especially if it still has its "Oldsmobile Cruise Control" foil decal.
Scott
If it's not connected to an engine vacuum source it won't affect anything.
You get a 68 Chassis Service Manual yet? Sounds like your car, like most 50 year old cars, has had its share of buggering. CSM will help you figure out what is and ain't supposed to be there. Also shows vacuum line routing.
Buggering is a good way to put it. 😂
Oldsmobiles don't usually get it as bad as some others. Imagine what Chevrolet and Pontiac A-body folks go thru after 50+ yrs. I have a term I like to use and seems to especially apply to Chevrolet- POS "Previous Owner's Stamp". You cannot get away from it on a Chevelle/Camaro/Nova and it's a big reason I try to not get involved with one. Get tired of correcting somebody else's half-assed mess.
None of these missing vacuum lines are going to cause any vacuum issues for your engine unless, as I said, the port on the carburetor where that vacuum line would attach is not capped.
