Clutch Recommendation
Old November 27th, 2021, 06:30 PM
oldsmoboogie's Avatar
I am looking for advice on what clutch to buy. I am purchasing a TKX trans soon and I don’t know what clutch to get. It is going behind the 355 i am building and will make it’s way into the 64 at some point in time. I have looked at McLoud, Centerforce, and Spec my concern is i don’t want too stiff of a pedal. With about 400 hp and a fairly light car I think a street type clutch will be fine, but I don’t have a lot of experience with manual transmissions. I would like to hear any good or bad experiences with these clutches, thanks.
oldsmoboogie is offline
Old November 27th, 2021, 07:33 PM
72Cutlass S
gs72's Avatar
Look into a hydraulic clutch conversion. Then pick the clutch you want. The right hyd. System will make a stiff clutch feel acceptable.
gs72 is online now
Old November 28th, 2021, 03:37 AM
Tri-Carb's Avatar
Centerforce Dual Friction for a light pedal feel without using hydraulics. I have used several with larger engines making a lot more torque.
Tri-Carb is offline
Old November 28th, 2021, 06:27 AM
Originally Posted by Tri-Carb
Centerforce Dual Friction for a light pedal feel without using hydraulics. I have used several in larger engines making a lot more torque.
^^^This.
joe_padavano is offline
Old November 28th, 2021, 07:52 AM
'70 4-Speed W Machine
tnswt's Avatar
Running the Centerforce Dual Friction right now after Joe P, and others recommended. Very satisfied.
tnswt is online now
Old November 28th, 2021, 09:06 AM
joesw31's Avatar
I have used Hays without issue. I recommend their street clutch.
joesw31 is offline
4-Speed
April 10th, 2020 03:28 PM
Onit
June 18th, 2019 07:55 AM
allyolds68
April 27th, 2016 06:13 PM
47 Convertible
April 3rd, 2014 07:56 AM
RandyS
March 8th, 2014 05:07 AM
Quick Reply: Clutch Recommendation
