Coil-over Shock for '66 Toro
Old February 8th, 2017, 10:36 AM
simrek1's Avatar
Hi, Has anyone put rear coil-over shocks on a '66? Mine has them but they need replacing. Does anyone know of an "off the shelf" shock that will fit?
Thanks,
Paul
simrek1 is offline
Old February 13th, 2017, 09:27 AM
simrek1's Avatar
Solution
I found a coil-over that is almost identical to the OEMs, it's the Gabriel 43140 Rear Load Carrier Shock.
They worked great and the ride height is perfect. $85. The alternative was custom built shocks for $250.
simrek1 is offline
Old February 13th, 2017, 10:14 AM
I'm glad you found a suitable shock. I was going to mention it might be worthwhile to check out Kanter or Fusick.
Olds64 is online now
Old February 28th, 2017, 03:16 PM
Mostly Gristle
bluecab's Avatar
Sporty!
As far as I know, the stock configuration just used single leaf springs.
Is this a helper for worn leafs (leaves) ?
Might be a nice addition to help handling..
bluecab is offline
Old February 28th, 2017, 03:46 PM
simrek1's Avatar
Yep, original leaf that's a bit tired.
simrek1 is offline
Old March 1st, 2017, 11:57 AM
DocRocket68's Avatar
Pardon my confusion but how does a Camero shock fit a Toronado?
The mounts are different. The Toro uses a stud on both ends and the ACDelco 519-8 has an "eye" with 2 bolts. Please explain how you installed these.
Brian
DocRocket68 is offline
Old March 1st, 2017, 02:19 PM
simrek1's Avatar
Sorry, wrong shock. I ended up using Gabriel 43140 Rear Load Carrier my shocks. If memory serves me the ACDelco equilateral is 519-34. I research the compressed length and the shock travel to get as close as possible to my OEM shocks. The mounting configuration of my shocks were as pictured below:
Are you sure that you don't have the front shocks pictured?
Good Luck,
Paul
simrek1 is offline
Old March 1st, 2017, 03:13 PM
Thanks for the clarification. Apparently the early 66's used a different rear vertical shock than the late 66 to 70 Toronados. Loop verses stud is the difference. As I have a 68, the search continues...
Old March 2nd, 2017, 08:05 AM
simrek1's Avatar
Lookup the extended and compressed lengths of you OEM shocks, then compare that to the off the shelf shocks and see if you can find a close match. Start with the Gabrielle, ACDelco and Monroe lines of specialty coil over shocks.
Good luck,
Paul
simrek1 is offline
Old March 3rd, 2017, 12:23 AM
EightballZ's Avatar
this is really interesting. how would it affect handling and drivability i you have both leaf springs AND coil over springs on the rear axle? would'nt things get too stiff maybe ?
EightballZ is offline
Old March 3rd, 2017, 06:16 AM
simrek1's Avatar
My car had rear coil-overs in it already and the shocks themselves needed replacing. I replaced all seven shocks. I needed it more for ride height than stability. If you looking for more stability, check out replacing your horizontal rear shocks and or your steering Stabilizer shock.
simrek1 is offline
Old September 11th, 2017, 03:18 PM
66toro_mn's Avatar
Good information - just looked and my 66 must be an "early model" since I have the loop at the bottom of my rear vertical shocks
66toro_mn is offline
CLcutlass
Paint
28
February 6th, 2020 05:57 PM
Chris J
Suspension & Handling
September 24th, 2016 06:04 PM
matchek
May 7th, 2015 11:28 AM
pcard
June 4th, 2013 08:22 AM
FIRST 442
March 14th, 2012 01:40 PM
Quick Reply: Coil-over Shock for '66 Toro
