How to change the heater core
Old February 6th, 2017, 01:47 PM
deaddds's Avatar
Got a leaking core in my 1981 Toro. The shop manual does not have a step by step instruction. Mechanic thinks the dash has to come out. Any other way to do this? Thanks
deaddds is offline
Old February 6th, 2017, 02:37 PM
ELY442's Avatar
He is right. I did a heater core on a 84 Eldorado. Its the same car, different name. I had to take the whole dash out and the heater box is right behind it.
ELY442 is offline
Old February 6th, 2017, 04:13 PM
deaddds's Avatar
Any tips or tricks to doing it damage free? I'd hate to screw up the dash pad as its perfect still.
deaddds is offline
Old February 6th, 2017, 04:49 PM
Olds Fever
CRUZN 66's Avatar
If you have an 81 chassis manual, there is a step by step to remove the Instrument Panel Pad Assembly - Toronado Section 8B3... Use Fig. 8B3-29 on page 8B3-10
After IP is removed go to section 1B4... Use Fig. 1B4-13 to R&R heater core...
Last edited by CRUZN 66; February 7th, 2017 at 10:37 AM. Reason: Correct manual year from 83 to 81
CRUZN 66 is offline
Old February 6th, 2017, 08:57 PM
deaddds's Avatar
Thank you. I will look it up this weekend.
deaddds is offline
Old February 7th, 2017, 06:46 AM
The step-by-step instructions are in Fig 1B4-13 on page 1B4-9 of the 1981 CSM. These are not the most comprehensive CSM instructions I have ever seen, but unfortunately Step 4 says to remove the instrument panel.
joe_padavano is offline
5998DownUnder
June 9th, 2014 09:35 AM
dre
Drivetrain/Differentials
August 31st, 2011 11:04 AM
<gerardtsr@aol.com>
December 17th, 2004 04:46 AM
Chris L.
May 28th, 2004 09:44 AM
Quick Reply: How to change the heater core
