'66 Leaf spring bushings
Old March 1st, 2024, 09:30 AM
ourkid2000's Avatar
I think that the engineers who designed the 1st gen Toronados must have been smoking some heavy stuff.
Has anyone ever looked at that forward leaf spring bushing/mount? Good grief, what were they on? The nut for the bolt is accessible on the outside of the frame, between the body, with the open end of a wrench, maybe the box end if you're lucky. The head of the bolt, however, is recessed in a hole in the body where it mounts to the frame. It's pretty deep in there too, you can't touch it with your fingers (at least I can't).
God help you if you snapped that bolt off. Not only that, but if the bolt is seized in the bushing you're gonna have quite a time with that RH side with the rubber fuel lines right there. I guess you would have to torch off the bolts from underneath.......yikes. What a horrible looking job. It really looks like a "torch only" situation to me.
ourkid2000 is online now
Old March 1st, 2024, 12:28 PM
ourkid2000's Avatar
I checked, the nut is only accessible with the open end of a wrench. That's pretty lousy. I don't suppose it's a welded in nut?
Some pics of these beauties:
budg
November 23rd, 2016 01:48 PM
Troys Toy 70
42
August 20th, 2016 07:09 PM
79supreme
September 17th, 2015 09:37 AM
1966Oldsmobile
September 2nd, 2015 03:00 PM
71cutlass350
January 7th, 2014 12:34 PM
Quick Reply: '66 Leaf spring bushings
