Tech Editor's Desk Projects, papers, writings, thoughts, musings of our technical editor Joe Padavano. To begin with, he will be making threads and can approve posts to it if he wishes. This can be changed in the future if it does not work out well.
Gas smell from 66 442
Old August 19th, 2014, 06:48 AM
rhp454's Avatar
I have a gas smell coming from my 66 442 each morning when I go out in the garage. I replaced the gas tank and vent lines along with rebuilding the carb. I ordered a new gas line from front to back yesterday and will be putting it in. I can see no visible signs of gas leaking any where. I have a new vent free gas cap as well. It appears to do it when the tank is half full or more. Suggestions?
rhp454 is offline
Old August 19th, 2014, 07:00 AM
Mr. Johnson
rjohnson442's Avatar
Have a hole in the tank possibly if you only smell it when its almost full? Have any other gas stored inside the garage?
rjohnson442 is offline
Old August 19th, 2014, 07:32 AM
wmlewis's Avatar
Way back when.. 1968 to be exact, I had the same problem. Turns out the little umbrella needle/seat in the quadrajet had a small hole in it and when shut off a little gas leaked
out onto the intake manifold. Pull the air cleaner and see if there is some dried fuel residue
left behind. It got so bad that after driving to work it was so bad I pulled off the air cleaner
and fuel was boiling off the hot manifold... Scared the bejesus out of me, fortunately no fire...
Bill
wmlewis is offline
Old August 19th, 2014, 07:51 AM
drjr56's Avatar
Fuel drys up pretty fast but the smell might linger...Are you letting it run outside then checking for a leak. My issue was my fuel pump.The eight little screws holding it together came loose.Also had a leaking gas tank that leaked when the tank was 1/2 full or more.But the tank was not new.
drjr56 is offline
Old August 19th, 2014, 09:28 AM
66luvr's Avatar
A few years back I had the same problem with the blue 66 in my avatar (my Son's car). Smelled gas when over 1/2 tank of fuel. I looked and looked, changed the rubber lines at both ends. Still when over 1/2 tank smelled gas. I finally got it up on stands all around, got my magnifying glasses and my light and went under there determined to find it. I examined every visible inch of the line(s) and found nothing. So I am lying under there frustrated just looking. I notice some dirt, like brown dirt, on the fuel pickup/gauge thing. So I get some brake clean and squirt it, wipe it, can't really see anything. So I crammed my head as close to the area as I could and saw the problem. The fuel line goes through the metal circle/body of the thing and continues to the tank bottom where the sock fits. Where the line passes through gas was seeping and evaporating immediately, creating the smell but never dripping. Removed the fuel, removed the whole pickup, took it to my local radiator shop where it was re-soldered, never had another problem. It may take time but you can find it. Look for a dirt deposit (dust attached to a minute amount of fluid), or a dark spot on the line, then examine that area very closely. A minor amount of fuel will evaporate so quick it will never drip.
Of course I later changed to a 3/8 pickup and new line so now my fuel gauge doesn't go all the way to full. Not a problem but is an aggravation.
Good luck,
66luvr is offline
Old August 19th, 2014, 09:59 AM
hookem horns's Avatar
I had a bad seal on the sending unit on top of the tank. Only sloshed out a little when the tank was pretty full and usually evaporated before runnig down the side.
hookem horns is offline
Old August 19th, 2014, 10:41 AM
RandyS's Avatar
Good luck,
Hmm, your comment has me curious. What would the size of the fuel line have to do with the gauges accuracy? Could it possibly be that the arm on the sending unit needs to be bent down a little, as it may not be reaching the top of it's travel when the tank is full?
RandyS is offline
Old August 19th, 2014, 12:12 PM
66luvr's Avatar
Nothing at all, not much of a writer I guess, didn't make the point clear. The old one worked perfectly through the years and being removed and re-installed more than once. The new one, which was a GM part I bought many years back when they were cheap, does not work correctly.
Sorry,
66luvr is offline
fv64olds98
October 24th, 2014 07:49 PM
rhp454
August 19th, 2014 06:43 AM
Benton Quest
August 26th, 2012 03:43 PM
Dan Wirth
Paint
37
September 21st, 2009 08:11 AM
Keieljun
November 8th, 2007 01:30 PM
Quick Reply: Gas smell from 66 442
