Tech Editor's Desk Projects, papers, writings, thoughts, musings of our technical editor Joe Padavano. To begin with, he will be making threads and can approve posts to it if he wishes. This can be changed in the future if it does not work out well.
Looking to buy a one peice rear main seal for 371 engine
Old August 26th, 2014, 05:29 AM
Sid
Sid's Avatar
Can you tell me where I can purchase a rubber one piece rear main seal for a Olds 371 engine to replace the rope seal.
Thank You----------Sid Hiatt
Sid is offline
Old August 26th, 2014, 06:29 AM
59-59-59's Avatar
I'm not sure if there's even a 1 piece rear main seal you can buy new for a 371, but you can buy a 2 piece neoprene rear main seal from a company called Best Gasket
59-59-59 is offline
Old August 26th, 2014, 08:18 AM
Oldskeeper's Avatar
If you decide to use the best gasket, the paper work will tell you not to use any sealant on the outer surface. I found out the hard way that in the rear main seal groove there are two styles ( for 394) first type has a smooth surface and the second type has locking grooves to hold the rope from slipping, if yours has the type with the locking grooves you will need to add a small amount of sealant to fill these grooves. I didn't know this when I replaced mine and it takes 20 minutes for the oil to work its way out the rear end and drip on your floor.I replaced it with a new one and the same thing so I pulled the engine again and went back to rope, no more oil on the floor. I talked to a friend from Toledo who experienced the same problem and he informed me how BEST gaskets solved the problem. I'm doing another 394 for a convertible 98 and I now know how the seal installs.
Steve
Oldskeeper is offline
Old August 26th, 2014, 07:31 PM
Tedd Thompson's Avatar
I used a neoprene Best Gasket on my 324 last time with no problems. For years they(Olds community) has used Ford 292 neoprene gaskets to do the same thing but I always felt better using a gasket labeled for the car/ engine I was going to use it in . I don't think there is such a thing as a one piece gasket, just think about it how would you get it installed without a seperation in the gasket...Tedd
Tedd Thompson is offline
johnnyjaws
July 9th, 2014 09:55 PM
atkinsom
June 11th, 2014 07:14 AM
toneypenna
October 7th, 2010 05:19 PM
65cutty
September 23rd, 2008 10:07 AM
gearheads78
April 17th, 2008 05:03 PM
Quick Reply: Looking to buy a one peice rear main seal for 371 engine
