Tech Editor's Desk Projects, papers, writings, thoughts, musings of our technical editor Joe Padavano. To begin with, he will be making threads and can approve posts to it if he wishes. This can be changed in the future if it does not work out well.
Fuel pump question
Old September 3rd, 2020, 03:29 AM
69 Ol' Blue
Doug Carner's Avatar
Fuel pump question
I have a 1969 442 big block with air conditioning. I ordered a new mechanical fuel pump and it is much taller than the original. Which is correct for my application (taller or shorter)?
Thanks in advance!
Doug Carner is offline
Old September 3rd, 2020, 06:13 AM
Ozzie's Avatar
400 or 455?
Photos would help.
Ozzie is offline
Old September 3rd, 2020, 06:20 AM
69 Ol' Blue
[QUOTE=Ozzie;1276244]400 or 455?
455
Old September 3rd, 2020, 07:00 AM
69 Ol' Blue
Originally Posted by Ozzie
400 or 455?
Photos would help.
originally came with a 400 but replaced it with a 455. Pics of the old and new pumps attached.
Old September 3rd, 2020, 07:13 AM
The correct original pump for all 1969 442s (including H/Os with the 455) is P/N 6416836, which is the short pump with fuel return.
joe_padavano is online now
Old September 3rd, 2020, 07:30 AM
69 Ol' Blue
Thank you again sir!
Old September 3rd, 2020, 07:38 AM
Olds Specialist LOL
JOHNNYOLDS442's Avatar
I just bought a carter from rockauto, looks like the AC one
JOHNNYOLDS442 is offline
Old September 3rd, 2020, 07:43 AM
69 Ol' Blue
Thanks! Does it have a return line? Wht is their part number?
Old September 3rd, 2020, 07:50 AM
Olds Specialist LOL
yes it does, M6109
Old September 3rd, 2020, 08:00 AM
69 Ol' Blue
yes it does, M6109
That part number was not available under the 400 engine but did come up when I searched for the 455. I just ordered it. Thank you!
Old September 3rd, 2020, 10:11 AM
Don't assume anything you read in the RockAuto online catalog is correct. Determine the correct P/N independently, then order by P/N on RA.
Old September 3rd, 2020, 10:38 AM
Olds Specialist LOL
Yeah because anything I post is incorrect.
i won’t post anymore
Old September 3rd, 2020, 10:46 AM
I have no idea what your problem is.
The OP said that RA didn't list that P/N for a 400. I said that RA is frequently incorrect. Your P/N is the correct one, and if the OP simply searches on that P/N instead of searching by application, he'll get the right part.
Chill out, dude. Not everything is about you. Unless you have an ownership position in RockAuto, this has nothing to do with you.
Old September 3rd, 2020, 10:59 AM
Olds Specialist LOL
Just trying to help another member out by posting a part# for the guy.
There's no need to say "chill out" or "not everything is about you" for all to read
Like i said i will not post anymore
Old September 3rd, 2020, 05:23 PM
The pumps with the taller canisters are high volume pumps. I’m not sure if there are multiple pistons, or if fuel is stored in the taller canister.
matt69olds is offline
Old September 3rd, 2020, 05:28 PM
69 Ol' Blue
I thought about using it. I bought it. We but that was 20 years ago.
Old September 3rd, 2020, 05:38 PM
Do you have a reference for that info? Airtex says that both their short Olds pump (41567) and their tall pump (40736) are the same 40 GPH at 1800 RPM. Both are listed as 6.5 psi.
Old September 4th, 2020, 01:59 AM
No, I don’t have any documentation, I based my reply on a verbal discussion with Airtex on the exact part numbers you mention. Way back when I was planning a fuel pump swap to fit the Edelbrock heads I called Airtex. The man I spoke to said the large canister pumps were considered high volume.
I assume there has to be a reason for the large canister. And based on personal experience, I can say the 40736 pump is enough to keep up with the fuel needs of low 12 second 66 cutlass.
Old September 4th, 2020, 02:31 AM
I agree that there should be a difference (otherwise, why have two configurations), but their published data suggests otherwise. Of course, the published data says "40 GPH min", which may just be their lazy way of using the same table for both. I'm also trying to figure out what internal differences would provide extra volume. These are diaphragm pumps, so the only way to get more volume is to either increase the stroke on the diaphragm (which is possible by changing the length of the lever arm on the diaphragm side of the rocker pivot) or by using dual diaphragms. I guess I'll have to open one up and look at it.
Old September 4th, 2020, 05:14 AM
My other thought is maybe the larger canister is a like a storage “tank”, which I guess technically wouldn’t make it high volume as much as a reserve. I’m guessing you could fill the float bowl of a Q-Jet 2 or 3 times with the fuel contents of the canister.
Or, as you suggested, the larger pump has a longer stroke on the diaphragm. Or a combination of both? All I can say with any certainty is the 40736 pump does supply more fuel based on my experience with the 66 Olds. I was pretty impressed for a $40 pump from Advance auto
Old September 4th, 2020, 05:21 AM
The larger canister may help with hiccups from the tank, like a surge tank, but only the diaphragm motion fills the bowl. Now I'm really curious. I could see where the taller canister would allow for more diaphragm travel, but you can only flex that rubber so far, and the diaphragm diameter is the same in both. The other problem is that a reservoir of fuel next to the engine like that would seem to heat up, potentially causing percolation.
Old September 4th, 2020, 05:41 AM
Rocketguy's Avatar
This is from the 1971 EAM:
They're calling it a "surge dome". Could it be that the larger dome aids the flow via smoothing out the surging fuel?
Rocketguy is offline
Old September 4th, 2020, 11:35 AM
Ok, let’s settle this. Who has one of the large canister style pumps sitting around unused, willing to undergo a autopsy? The only one I have is currently in use on Dads 455 powered GMC truck.
Old September 4th, 2020, 11:42 AM
69 Ol' Blue
Since the pump was over 20 years old and i wasnt sure of its application, i busted her open for your review. Im not sure what i am looking at. Maybe the CO community can use this info.
Old September 4th, 2020, 06:18 PM
Unfortunately, we need a short pump to compare the diaphragm travel. I happen to have one I just replaced but it will be tomorrow before I can open it. I don't see anything obvious inside that tall cannister, however.
I was under the impression that this was the "surge dome", equivalent to the pulse damper added to the 1966 pumps.
Gone Johnson
May 18th, 2020 07:22 PM
BlueCalais79
November 6th, 2014 10:59 AM
ed burke
January 10th, 2014 04:07 PM
geckonz08
August 12th, 2008 08:49 PM
Quick Reply: Fuel pump question
