Correct 66 Tri-Carb Fuel Bowl Assembly Finishes
I have most all of the factory references and pictures which are in black and white.
clamp to filler tube: silver cad or zinc dichromate?
slotted top plate: stamped steel so dark gray?
through bolt into top: natural steel so dark gray?
Use flat washer under head of a hex bolt, flange head bolt, or hex bolt with no flat?
top for fuel bowl assembly: cast metal so use Detail Gray paint?
wire arms down to thumb screw: appears to have originally a shiny silver metal plating so use shiny metal paint?
The bail/wheel I clear zinc plate
The mounting bracket I gray phosphate
The bolt & lock washer I use black manganeese or black oxide
The clamp I clear zinc.
You probably have the same factory pictures I do. The parts that I clear zinc were probably cad from the factory. The one picture I have showing the setup close appears to have a lock washer on the mounting bolt not a flat washer. One thing that I have found is the heater hose clamp used before the filler tube is mounted on an intake bolt stud not the valve cover bolt like the PIM/assembly manual shows.
I've had a few original fuel bowls and the bolts always had washers. I have seen flat head bolts and recessed head bolts used but the pictures appear to have flat head bolts.
I did more than try. I did it. First, the clamp needed a slight counter clockwise twist plus a hole in the stem for the 3rd factory wiring harness mounting stake.
But, the break out drawing for an AC car showing the harness going over, and not under the compressor mount, I would say is incorrect. It nicely fits under the mount.
How about the heater hose doughnut bumper?
The diameter and aspect ratio in the factory picture above is nothing like the one sold by say, The Parts Place. The doughnut must have enough diameter to allow the heater hose to clear the tops of the bolt heads for both the AC compressor mount and the thermostat housing. Otherwise, there is a risk of chafing.
Yep I see that is exactly where it has to go with a bumper that size. Mounting the bracket over the intake gives you the elevation needed to do that. On the other hand if the bracket is mounted under the valve cover bolt you will need a bumper more the size shown in #7 above.
By the way what a beautiful car. I hate I was too late to get it.
The 9419234 washer is a flat washer, .41 ID X .73 D X .06 TK FLAT WA PHOS, and the 9418931 nut is a 3/8-16.
I can't find a page in the PIM that shows the part # for the fuel bowl washer.
Here are the factory 8x10 black and white photos. I don't see the foam bumper but then again this is probably a very early photo. Well, the coil mount is up on top unlike the early AL intake mount being in back down low. So this would have to be a Nov/ Dec or later photo.
Very nice. A friend had shared those with me.
Looking at those factory pictures takes me back to the recurrent debate about correct water hose clamps. If you purchase the typical clamp kit sold today, you will get 4 in number of the dreaded Corbin clamps. The rest are what I call double wire clamps. The 4 Corbin clamps are intended for the 4 ends of the two heater hoses. Accordingly, the water pump fittings will have a heater hose with a Corbin clamp while the bypass hose will have a double wire clamps on each end. Do I see this same set up in those pictures or am I seeing the obscure clamp that is not reproduced?
Here is a link to the clamp with McMaster Carr. I have seen the clamp on the reducer end but never on the heater core end & I've parted out many many many 66's.
https://www.mcmaster.com/products/ho...hose-and-tube/
Thanks again for another assist.
Reference the drivers side spark plug loom attached to the valve cover. Notice that in the picture the stem's shade does not seem to match that of the valve cover. I always thought the stem was painted the same color as the engine. Now, I suspect it is a natural metal finish. Can you give me a consensus on the correct finish?
Painted is good because I already have it painted. The picture had me questioning the accuracy of what I had done. However, my instinct is that unless the stem was already mounted to the engine driver’s side valve cover during its factory painting, its finish should be something else.
CUT-N-UP
September 7th, 2013 08:24 PM
