1955-56 Olds Fuel Pump block off plate
Old October 2nd, 2013, 04:56 AM
BenJammin's Avatar
Hi guys
I went out and fired up the olds yesterday. After cranking it for a long time, the fuel filter was still try. This is a good indication that the fuel pump probably needs to be rebuilt/replaced.
i have a few holley electric pumps laying around, so i was going to throw one in. I wanted to remove the mechanical pump and block it off, but i don't see any 1956 324 specific fuel pump block off plates out there. Do you guys know what part and where to remove my mechanical pump and block it off?
Thanks!
BenJammin is offline
Old October 2nd, 2013, 05:29 AM
Collector of Stray 55's
Olds Dad's Avatar
None that I'm aware of - be careful eliminating that pump - it also has a vacuum pump integral with it that runs your wipers - so unless you've converted to electric wipers you need that pump.
I have supplemented mine with an electric - left the OE pump in place.
Olds Dad is offline
Old October 2nd, 2013, 05:36 AM
BenJammin's Avatar
Yeah, i was planning to go electric on the wipers.
You left the pump in place? did you just block off the fuel inlet and outlet then? or did you loop a hose around to both? I was worried about leaving the mechanical pump in place with it probably being bad.
Old October 2nd, 2013, 05:43 AM
Rocketowner's Avatar
My '55 Was Requiring Much Pumping To Start It If It Sat For A Couple Of Days,So I Installed A "In Line" Pump Back Near The tank , And A Lighted Switch Where I Could Turn It On For Cold Starts. I Left The Original Pump Intact and Just Use The Electric For Starts When It Has Not Been ran For A Few Days, Then Cut It Off And It Runs Fine On The Original.if The Original Evers Quits Pumping My Electric Will Be My Backup! Larry
Rocketowner is offline
Old October 2nd, 2013, 05:57 AM
Olds Dad's Avatar
Mine is similar - actually wired mine to the hand brake indicator light - when the hand brake is on, the pump is on - of course my situation was for starts only as Rocketowner said -
You should consider having this wired to something live when the car is running so in the event of a crash, the pump isn't dumping fuel everywhere.
Olds Dad is offline
Old October 2nd, 2013, 06:21 AM
BenJammin's Avatar
I was going to use the holley oil pressure switch so it only pumps when it sees oil pressure.
Old October 2nd, 2013, 06:23 AM
BenJammin's Avatar
When my fuel pump was bad on my mustang (after it sat for years) it was pumping gas into the oil pan instead of up to the carb. I don't want a similar situation here, which is why my thought was to remove it/disable it.
Old October 2nd, 2013, 07:22 AM
Proud Viet Nam Veteran
redoldsman's Avatar
If you want a blockoff plate you will probably have to fab one from a piece of flat steel. If the fuel line is disconnected I don't believe there would be anyway it could pump fuel into the oilpan. That was probably the result of a busted diaphragm and the gas leaked through the pump into the crankcase. My 54 has a blockoff plate and an electric pump back by the tank. I am going to install a relay that grounds with an oil pressure switch so if the engine dies, the pump will turn off. Right now it is tied to the ignition switch with a toggle switch in between the ignition and the pump. The wipers are vacuum and run to the carb but I will never be in the rain anyway (I hope).
redoldsman is online now
Old October 2nd, 2013, 08:25 AM
Ozzie's Avatar
Lightbulb Another option
If "pretty" is important, and cost doesn't matter, here's another option:
http://www.dashman.net/category.html?id=12
These were available more back in the "old days", and might be found on the used market somewhere.
Functionally, the fabricated steel plate will work just as well.
While many things can disable the original pump, a leaking fuel hose (it will suck air) from the chassis to the pump or a distorted bottom casting (where the glass bowl is) will allow air to enter the system and weaken or stop the pump's pumping capacity.
Ozzie is offline
Old October 2nd, 2013, 09:19 AM
BenJammin's Avatar
Hey! A block off plate! thanks for the info!
I do plan to be in the rain, so i thought i would convert to an electric wiper motor, but i honestly haven't given it much thought. I cannot imagine the vacuum wipers would really work well
Old October 2nd, 2013, 09:35 AM
redoldsman's Avatar
No question, electric is the way to go on the wipers. There is a thread on here about that subject. Tedd will probably speak up.
Old October 2nd, 2013, 10:58 AM
BenJammin's Avatar
I found the post about it. https://classicoldsmobile.com/forums...oday-55-a.html
thanks guys!
Old October 5th, 2013, 05:17 PM
BenJammin's Avatar
Just FYI...i confirmed that my fuel pump is pumping...nothing! i bottle fed the inlet from a gas can and cranked the starter. the fuel pump didn't pull anything in. the inlet line was dry. So for now i will bypass it and throw one of the holley electric ones in it. down the road i might rebuild this stock one.
Old October 5th, 2013, 08:45 PM
Ozzie's Avatar
Smile It's repairable
The original pump is fairly simple. There are two valves and a diaphragm and a filter. Usually either the diaphragm is cracked or petrified, one or both valves are leaking, the filter or strainer (there were at least two possibilities) is plugged, or the casting is distorted at the sealing surface allowing the pump to suck air. All can be cured if you have the new parts.
Ozzie is offline
Old October 6th, 2013, 07:09 AM
BenJammin's Avatar
I just bought this. Easier and ultimately cheaper than screwing with an electric pump
http://www.ebay.com/itm/1958-Oldsmob...d19fd6&vxp=mtr
i compared all of the pictures and this looks to be a pump that will work...hopefully...
I can't even rebuild mine for $60
Old October 6th, 2013, 07:44 AM
Ozzie's Avatar
Thumbs up Looks good
It looks like a good solution, as long as the rebuilder did his work properly. You got an air dome, which many rebuilders omit, and, it appears, a real FP-57 filter, which I have seen advertised for $60 by itself. Be sure the flex fuel line (chassis to pump) is in good condition, do a good installation, and you should be set for a long time.
Ozzie is offline
Old October 6th, 2013, 08:28 AM
Tedd Thompson's Avatar
My vote would be to go with a rebuild before having to mess with a electric pump and switch system. Most electrics I have used sounded like woody wood pecker was under the car and after all you are only talking about two or three bolts and a gas line or two to mess with to remove the old pump. Not the best place to work if you don't have a lift but very doable from the top if your agel enough.
Before you give up on the pump you might see if gas is even getting to the pump. Sometimes the pickup tube filter gets completely gummed up and no gas will get through.....Just my thoughts.....Tedd
Tedd Thompson is offline
Old October 8th, 2013, 08:48 PM
BenJammin's Avatar
Thanks Tedd. I did put a rubber fuel line straight from the inlet to my red gas can then cranked the motor. The inlet to the pump was bone dry
Old October 9th, 2013, 09:41 AM
BenJammin's Avatar
Originality is not really a concern of mine. if this is a valuable filter to you or someone here doing an original restoration, let me know. I'd rather someone have the filter that really needs it for originality! I can just throw a paper one in it for myself.
mmcilroy
August 26th, 2010 08:42 AM
Mongoose
December 4th, 2009 05:11 PM
66ninetyeightls
November 2nd, 2009 05:03 PM
Redog
December 14th, 2007 01:17 PM
Quick Reply: 1955-56 Olds Fuel Pump block off plate
