Steel vs Cast Iron Distributer Gear
Old April 25th, 2016, 09:29 AM
71cutlass350's Avatar
Hi all, I'm looking at buying a HEI distributor and it has a steel gear on it and I was wondering if this would be ok on a Comp Cam hydraulic flat tappet cam blank that was custom ground by dick miller or would this cam take a cast iron gear? Don't feel like wiping out my cam so I want to make sure I go with the right option. Thanks
71cutlass350 is offline
Old April 25th, 2016, 09:51 AM
Octania's Avatar
Aren't all Olds dist'r gears made of steel? Unless you buy a brass/bronze one.
Octania is offline
Old April 25th, 2016, 12:07 PM
I'm not sure about what material the stock gears were made of but a lot of aftermarket distributors have the option of either steel or cast iron along with bronze.
Old April 25th, 2016, 12:27 PM
This should help:
http://www.enginebuildermag.com/2009...tributor-gear/
oldcutlass is online now
Old April 25th, 2016, 02:09 PM
Thanks for the link. That site makes it sound like i would need a cast iron gear. I also called comp cams and dick miller for their opinion. The comp tech said he recommends a cast iron gear but when i asked Dick he said the steel will be fine. So not sure what to take from that.
Old April 25th, 2016, 02:53 PM
Doesn't comp make a cast iron gear for Oldsmobile? I would run with the recommendation of the cam manufacturer.
Old April 25th, 2016, 05:19 PM
Ok found the cast iron gear on comps website but its $98. Yikes
85cutlass6.6
August 11th, 2011 06:55 AM
815Cutlass1972
November 4th, 2010 08:47 AM
timsmachine
September 24th, 2010 06:20 AM
Kace
August 25th, 2010 05:41 PM
dan2286
July 16th, 2009 07:14 AM
Quick Reply: Steel vs Cast Iron Distributer Gear
