Steel vs Cast Iron Distributer Gear
Hi all, I'm looking at buying a HEI distributor and it has a steel gear on it and I was wondering if this would be ok on a Comp Cam hydraulic flat tappet cam blank that was custom ground by dick miller or would this cam take a cast iron gear? Don't feel like wiping out my cam so I want to make sure I go with the right option. Thanks
This should help:
http://www.enginebuildermag.com/2009...tributor-gear/
Thanks for the link. That site makes it sound like i would need a cast iron gear. I also called comp cams and dick miller for their opinion. The comp tech said he recommends a cast iron gear but when i asked Dick he said the steel will be fine. So not sure what to take from that.
