whats the best small block for my car?
Old October 4th, 2006, 06:55 PM
86cutlass supreme's Avatar
Exclamation whats the best small block for my car?
whats the best small block for my car?i own a 1986 oldsmobile cutlass supreme coupe.it has a 3.8L v6 engine.the car has a full frame and no a/c.its rear wheel drive with a limited slip dif.i was also wondering whats a good posi rear end that will fit ?if u could help me out it would be GREATLY appreachated
86cutlass supreme is offline
Old October 5th, 2006, 03:56 PM
Redog's Avatar
1972 Olds 350 Block, casting 395558
Redog is offline
Old October 5th, 2006, 05:58 PM
Tom Servo's Stunt Double
texasred's Avatar
A 72? If you are going to be that specific, at least pick something with smaller dish pistons and smaller combustion chambers.
Almost any 350 will do you great....or 403.
Check out www.oldspower.com
C.J.
texasred is offline
Old October 5th, 2006, 08:00 PM
Redog's Avatar
The 350's past 76 (I think it's 76 and up) are not as strong, block wise. In the late 70's they started using "webbing" to make the blocks
1968 to 1972 blocks are great for a build up, but the best combo is the 1972 block with the 7A heads. That's if your going to build it up, if just for a daily driver that will see very little track time, any Olds 350 will do
Redog is offline
Old October 6th, 2006, 02:56 AM
texasred's Avatar
Windowed mains '77 and up. 395558 cating was used 68-76. #5 heads (68-69) are the best flowing of the small block heads.
C.J.
texasred is offline
bocoogto
August 26th, 2023 06:09 PM
ramrod31
June 2nd, 2013 08:22 PM
olds4life
February 9th, 2010 08:48 AM
davepnola
December 18th, 2009 05:50 AM
citcapp
January 31st, 2009 04:01 PM
Quick Reply: whats the best small block for my car?
