vaccum gage and timing
I was told its a better way.
You hook up the timing light, set your idle to the specified rpm and use the timing light to set your "timing mark" on the harmonic balancer to the specified advance.
Use a vacuum gauge to set your idle mixture screws.
Supposedly there are old timers that can tune a car by ear or with a small glass of water on the air cleaner. I've never seen it though. Plus, why try to be that cool if you have tools to do it with?
It's really not that hard to do by ear, within 3-4 degrees. But that isn't good enough.
not trying to be cool, I can get a precise timed engine if vaccum is at the highest then backed off just a little, and with a cam there timing is just a starting point, air fuel mixes? tried that last nite and it works also went for the highest setting then tighten 1/4 turn, car runs the best it ever has since rebuild, doesnt load up hot and no stumbling. yes the rpm must be set and dist vac blocked.
jonesolds442
December 3rd, 2013 05:00 PM
