Starting issue
Starting issue
I know I have alot of posts, but I want to keep the topics separate.
Cold start (in 100 degree temps) car fires right up.
After car is warmed up, car srtuggles to start and I have to press and hold on the gas peddle to get it to turn.
However, if the car is warm, and I start it within 3-5 minutes after its been shut off, it fires right up.
I just upgraded to an edelbrock 1406 carb w/electric choke, but the choke isn't hooked up b/c it struggles to start. I regret getting the electric choke, anyone wanna trade for a manual one?...but I digress
Starter is a year old...is it overheating?
As far as I know the battery is good, and the voltage regulator is new.
Could it be the Alternator?
I really think it's the carb, but I haven't adjusted it much and I'm not a carb genius, so I don't know.
Any ideas?
Any ideas?
If you don't have the choke hooked up then I suggest setting the choke first. It is a realtively simple procedure. If setting the choke doesn't fix your problem then you can continue troubleshooting.
First make sure the engine is running below 210*. Use an infared thermometer to check it by the temp switch.
If running over that, then you need to get that fixed first.
I had that issue (running 220*+ due to incorrect 2 row radiator & bad fan clutch) and it caused the same symptom you have. After fixing that, the starter issue went away!
Second, the wide 455 starter-block bracket can be installed in place of the skinny 350 bracket. The wider one acts like a heat shield, to reduce reat soak from the nearby exhaust pipe.
Lastly, the starter can be replaced with a stock type high torque starter with additional windings inside or one of those mini things.
1970cutlasssupreme
October 4th, 2013 10:29 AM
