rocker bridges - 1967 330
I was speaking with an old salty mechanic this afternoon regarding my tapping 1967 330. He suggested that it was the bridges on the rocker arms. Does that sound plausible or does anyone have any experience with that part failing?
My engine still has the one-piece units in place.
I think it is a bad lifter. The engine probable has a lot of sludge. Run a quart of ATF fluid in the engine. The tick should go away. If the rocker bridge is broke the engine will have a miss to it. The engine is 43 years old, the lifter is proabale wore out.
Gene
Gene
I did that last oil chance - 20/50 replacing a quart with ATF - about 1300 miles so far, no change; I even dumped other "miracle" type stuff (mostly ether, I believe) into the crank case - no change yet.
Don't 330's have rocker setups like this or is that just the older ones??? At least my brother inlaws did. His was noisey above 2000RPM. We found a few of the rocker bolts loose. Once we tightened them up the noise went away.
![](https://sphotos.ak.fbcdn.net/hphotos-ak-sjc1/hs557.snc3/30463_10150175895680587_865500586_12172257_6182847_n.jpg)
![](http://www.supercarsunlimited.com/images/16006.jpg)
CutlassLegend
September 21st, 2011 02:56 PM
