oil light comes on when the car stops
when I apply my brakes the oil light comes on flickering on & off
also my generator light stays on but very dim, any ideas what could cause this?
This is usually caused by a bad diode trio, or external voltage regulator, depending on the year.
You might consider getting a cheap mechanical oil pressure gauge to install in place of the switch, until you get the problem figured out. The oil light switch closes at about 6psi, so that is way too low to continue running the engine.
Hope it is one of the easy problems mentioned...
59Olds98
December 25th, 2013 08:20 AM
