How to identify an original 350 rocket
Here's a thread with pictures showing some of the different locations for numbers.
John
https://classicoldsmobile.com/forums...s-engines.html
John
This is good information to know, I recently bought a car with a much newer motor in the engine bay, something I wish I would have known before buying it. Oh well, you live and you learn. I now look for the numbers and research them using my smart phone prior to making an offer.
A big thanks to all the CO members for the information they provide to all of us novices.
- Std Olds engine,
- Rocket Olds engine,
- "GOLDEN" Rocket Olds engine.
It's never clear what the defining differences are, so let's just run with "all Olds engines are 'Rocket' engines" and if they are a Gold painted 64-76 350 [and/or some 1950's models??] then it's a Golden Rocket.
Popular legend, however, has it that there are
- Std Olds engine,
- Std Olds engine,
Mine is a 72' , its definitely gold , & it has a sequence of numbers(which i dont remember off hand) right above the water pump. Is there some kinda registry that you can input that number into in order to verify its a 350 rocket? I find difficult to believe that olds would put the exact same number on every single 350 that rolled off the line.
395558 2 is 68-76 Olds 350 block
#7 heads are from 1971
From Oldspower.com
From Oldspower.com
All 1971 350's use #7 heads. Valve springs were different depending on application. Rotator style spring retainers were used on ONLY the exhaust springs. Induction hardened valve seats for use with unleaded fuel.
6 digits
395558 - 2 is the common '68-'76 350 block.
7 heads are 1971 issue
look for a teensy "A" subscript to the 7, "7a" heads are 1972 issue. I use a lower case "A" to represent in text a teensy "A" in real life.
Number on oil fill tube- 1st digit is year of issue
1xxxxxx = 1971
2zzzzzz = 1972
etc.
not all years have this feature.
VIN stamp on the block just below the LH head's "7" or "7a"
31M100123 for example
3 = Olds
_1 = 1971; 2=1972, etc.
__M Michigan built, Z- CA built, etc.
___100123 = the serial # of the original car, last 6.
This started in 1968.
Carb number also has the year of issue incorporated. LH side, aft end, looks like
7041250
7042250 etc.
"42" = 1972 issue; "41" = 1971
God forbid they just use "71" for 1971, ya know.
Google numbers like that with a keyword for all manner of fascinating [mis]information.
1xxxxxx = 1971
2zzzzzz = 1972
etc.
3 = Olds
7041250
7042250 etc.
Hi great info in here guys. I found a 1972 olds 350engine & Trans ol guy asking $400 for complete engine and all brackets + alt + power steering etc.. Dont know much about it yet but gonna try and get him to 300 .
However, I found these interesting articles online and thought you all would enjoy it the 2nd one tells you how to identify all olds motors page 13.
https://www.gmheritagecenter.com/doc...2_Info_kit.pdf
Engine Modification and Tuning Guide Oldsmobile
http://wildaboutcarsonline.com/membe...1-2_V_11.1.pdf
go to page 13.
Everyone have an awesome days..
go to page 13.
