Converting from single to dual exhaust
Old March 19th, 2016, 07:42 PM
dalilama's Avatar
I've got a 1972 Cutlass with a single exhaust 350 engine. It has the crossover pipe from the driver's side exhaust manifold to the passenger side exhaust manifold. I'm considering going to a dual exhaust with an OEM-like dual exhaust like this one: http://www.ebay.com/itm/350789549979.
A few questions:
1. Any routing/interference issues that I may run into given this car currently has a single exhaust?
2. If a get a muffler shop to hang this (especially if the answers to the above are a bit scary) do I need to scare up a cap for the passenger side crossover exhaust port or should they have these?
3. Any tips from those folks who have done this before?
Thanks -
dalilama is offline
Old March 19th, 2016, 07:49 PM
You can purchase a cap or the muffler shop can make one. Should be no issues with the install. You also might contact a good muffler shop on fabbing a custom exhaust that will look just as nice or better than the one your buying.
oldcutlass is online now
Old March 19th, 2016, 08:00 PM
dalilama's Avatar
Thanks Eric - I'll ask around to see what I can get from some shops.
dalilama is offline
Old March 19th, 2016, 08:22 PM
To give you another option, Scott at Classic Exhaust did a good job on mine, and it arrived all in one box only a few days after I called him.
MDchanic is online now
Old March 19th, 2016, 09:26 PM
Proud Viet Nam Veteran
redoldsman's Avatar
Years ago I had a muffler shop fab the duals on my 72 Cutlass convertible. This really does look to be a good price on this system. As Eric mentioned, most muffler shops can make a system that will look and fit like factory.
redoldsman is online now
Old March 20th, 2016, 07:57 AM
The factory simply capped the crossover port on the passenger side manifold, even on the W-31 motors. Nearly every Olds vendor sells a repro of the cap.
joe_padavano is offline
Old March 20th, 2016, 12:48 PM
lemoldsnut's Avatar
I used one of these systems several years ago. It was ok not great. By the time you purchase hangers and clamps and do the work it is just a little more to have a quality system done and you don't do the work. I was just quoted $600 for a complete system installed with either Magnaflow or flowmaster mufflers. When you figure shipping on this system and the extras needed then your time and all. It is worth the $150 -200 more for a built to fit on the car system installed.
Just my input.
Not to mention "the parts place" is not the best place to do business with.
lemoldsnut is offline
Old March 20th, 2016, 02:14 PM
I've got a little different take on this. Unless you are going for an exact factory-style exhaust, why use anything that isn't mandrel bent? This photo is from the ebay ad:
Compare to mandrel bent:
I don't know of many muffler shops who have mandrel benders, either.
Old March 20th, 2016, 03:42 PM
For what he's wanting a press bent muffler shop system will suffice. We aren't taking much flow difference that warrants the cost of a mandrel bents system. In addition there may be shops that can provide a mandrel bent system in his area if he so chooses.
I don't like the ebay system because its probably cheap tubing and mufflers.
Old March 20th, 2016, 04:07 PM
dalilama's Avatar
Just my input.
Well no shipping since The Parts Place is about an hour away. However reading this and the other replies I'm going to visit a few muffler shops and see what they can do.
Great input folks - thanks!
dalilama is offline
Old June 27th, 2016, 11:08 AM
Cutty77's Avatar
I was curious as to what kind of luck you've had with this. 1 thing everyone failed to ask was if your transmission cross member was a dual hump or single hump. If it's single you are going to need to swap it out or your exhaust will be sitting pretty low.
Cutty77 is offline
Old June 27th, 2016, 11:20 AM
Because we didn't have to. Every single 1964-1972 Cutlass has a double hump crossmember. the single hump crossmembers weren't used until catalytic converters came out in the 1974 model year.
Old June 27th, 2016, 11:27 AM
Cutty77's Avatar
I see. That I did not know.
Cutty77 is offline
Old June 27th, 2016, 11:43 AM
delete
droptopron's Avatar
Unless you need something special I'm a big believer in going to a local guy if you can find one. I went from a cat & a y-pipe & two mufflers to true duals off Thornton manifolds into my existing mufflers & tail pipes on my '79 Trans Am. I found a local guy to bend the head pipes & install for around $275. That included him effing with the tail pipes that were on the car already & from one of these kits that didn't fit right to begin with.
droptopron is offline
Old June 27th, 2016, 09:03 PM
4 Barrels of Laughs
quaddriver's Avatar
Location: I moved to pittsburgh so I can be near Primantis
My 74's were dubbles.
IIRC, cats came out in 75 for these cars.
quaddriver is offline
Old June 28th, 2016, 06:16 AM
ELY442's Avatar
Mine too and it had a points distributor.
ELY442 is offline
Old June 28th, 2016, 06:40 AM
crimsoncolby's Avatar
As long as you're shopping around, give Scott at Classic Exhaust Inc a call. He's in Geneva, OH. You can buy a whole system or just pipes (I bought my own mufflers) and was very happy with the way they fit my '75 Laguna S-3 when I switched from single to dual exhaust. He bends pipe according to original GM bend cards.
crimsoncolby is offline
Old June 28th, 2016, 06:43 AM
4 Barrels of Laughs
quaddriver's Avatar
something dawned on me, my 76 and 77 were single hump, BUT the A body member was pretty much universal and I dunno if olds was vertified for export, but the chevies WERE and many many cars went north, south and overseas with non-emission equipment and in some cases, factory duals. Sadly, no one cared and they are likely korean container ship steel right now, but there still might be a population of parts to find.
Old June 28th, 2016, 06:45 AM
4 Barrels of Laughs
quaddriver's Avatar
<perk!>
does he work in T304 or 409 stainless? my sub crys for a set of factory bends in dual flavor for the big block.
dalilama's Avatar
Hi Cutty - I wound up bringing the pipes and muffler to a local shop since I needed a torch to "tweak" the pipe on the driver side to snug up to the manifold and to TIG weld the trumpets onto the exhaust sections. I had neither capability in my garage. They charged me $250 to put it all in. No issues with the cross member at all. They got it to fit very tight. Drones a bit a low speeds compared to the stock single exhaust but cruises with a mellow tone. I may change the mufflers at some point but overall very pleased with the conversion. Also picked up a little HP from what I can tell. Definitely accelerates better
dalilama is offline
Old June 28th, 2016, 07:02 AM
I know he works with 304 stainless. Not sure about 409. Nice guy...give him a call.
Old June 28th, 2016, 07:25 AM
That's what I said on March 19th.
Old June 28th, 2016, 07:33 AM
Cats did come out with the 1975 model year and all crossmembers from then on were single hump. I was not 100% certain if all 73-74 cars got double hump or not, which is why I said 64-72 above. Since the OP's car was a 72, that's as far as I needed to go anyway.
Old June 28th, 2016, 08:10 AM
Cutty77's Avatar
Cool. I know converting to dual made a huge difference on my 77. The rest is stock......for now.
Cutty77 is offline
Old June 28th, 2016, 08:12 AM
4 Barrels of Laughs
quaddriver's Avatar
I did, no dice :-(
Old June 28th, 2016, 09:17 AM
Oops...sorry about that, Eric. Another senior moment, I guess.
Old June 28th, 2016, 09:35 AM
It's just that with all of the different suggestions here, there are two separate people who have both had good results with Scott, and who recommend him.
I'd say that makes him worth considering.
Old June 30th, 2016, 11:37 AM
delete
droptopron's Avatar
It's the trumpet tips
JJRitchey
January 11th, 2012 06:20 PM
65OldsDelta88SuperRocket
October 27th, 2011 09:16 PM
BStone
16
August 12th, 2011 10:17 AM
CutlassLegend
Brakes/Hydraulic Systems
August 7th, 2011 05:15 PM
Dant
June 27th, 2011 01:38 PM
Quick Reply: Converting from single to dual exhaust
