computer controlled carb help?
can someone tell me where these green wires in this picture connect to? i can't find anywhere on the carb or intake where it would connect. the car is an '85 delta 88
This is why you MUST read the tuning section of the factory Chassis Service Manual if you plan to do any work on these CCC cars. That test connector is provided so you can use a regular dwell meter (on the SIX cylinder scale) to monitor the mixture control duty cycle while adjusting the idle mixture screws.
skryla
January 14th, 2015 07:03 AM
at3reg98
April 22nd, 2013 02:47 PM
84oldsDelta88
August 1st, 2012 09:25 PM
