Computer controlled distributers
Are some of the later year Olds engines equipped with a computer controlled distributer. These are commonly refered to the the small cap HEI. If this exists, would it work on the older engines like the 400, 425 or the 455? I am looking at a computerized throttle body injection system that can control the ignition system without have to fork out alot of green for a MSD system. Thanks, Dean
I have a HEI distributor from a 350 and that will not work with the original style OB4 intake I have (square port intake). I guess what I need is a 88 thru 90 307 style which should be the small cap HEI that is computer controlled with a separate coil (not in the cap). Dean
skryla
January 14th, 2015 07:03 AM
84oldsDelta88
August 1st, 2012 09:25 PM
