Compressed air from oil filler tube
I did a quickie leakdown test on several of my cylinders on my '54 a few days ago. On both tests, there was a strong rushing of air out of the oil filler tube (I did make sure each piston was at TDC before testing.) Also, when I put my hand over the filler tube and blocked it, I could hear the air escaping from somewhere around the back of the motor (I have not been able to determine where, though.)
Is this an indication that my rings are bad? The motor does burn a some oil.
It very well could be. If you were to squirt some oil in the cylinder being tested and get a better reading and/or less air passing into the crankcase then you definitely have bad rings.
The thing I don't understand is, when I did my compression readings, they were all between 103 and 115. When I squirted some oil down in one of the spark plug holes, the reading stayed the same.
Before you do anything as rash as removing the intake examine the oil filler cap for oil running from it if you put it on a white paper towel and let it sit for a few minutes.
You really need to get on eBay and buy a shop manual for this guy. Printed or on CD run between $30 and $50. You'll be glad you did.
OK, I looked all over the rear of that motor, both on top and from underneath and could not find anything at all that looked like a crankcase breather tube. Could it be possible that it was taken off and never put back on? Where does it connect to the engine at? If it's missing, wouldn't there must be some kind of connection or something?
If there is no breather tube or PCV valve on an engine the crankcase pressure would be blowing oil out from any point an even very minute opening to the crankcase is found and right slap smack out of the oil filler tube as well.
Go look again!
Aside from the fact you need to find the breather tube, after reading your original post again I would conclude that the engine has worn rings or tapered cylinder walls, maybe both. Meaning your oil loss is from blow-by. The fact you mentioned hearing air escaping from the rear of the engine following an attempt at a leak down test confirms there is a breather tube there someplace unless it has fallen out or been knocked off the engine (not likely).
And he would have called it a "road draft tube".
My guess is: Someone removed the tube, and plugged the hole with steel wool.
If so, those fine folks at Radiators.com can probably fix you up with one, for about 1/3 what the dealer charges.
Not by itself.
How much air was escaping, from the oil filler, during your tests? During normal driving, how much oil accumulates in the breather (filler) cap?
More than 1 quart in 1000 miles?
Right where they should be.
Norm
If Texascarnut knew anything about '54 Oldsmobiles, he would know that, since air follows the path of "least resistance" this is the normal place for it to escape.
He would also know, that at the rear of the block, below the distributor, and above the bell housing, is where the fumes escape through the "road draft tube" when (and only when) the car is moving. If the tube is missing, there should be a hole where it was originally connected.
I
Norm
I
Norm
I think you need to get over yourself. You'll certainly have a lot better relationship with people with a different attitude than you seem to consistently have.
BTW, I found the hole where the breather tube is supposed to be. It isn't there, so someone must have taken it off and thrown it away.
I did find this curiosity hooked up to the vacuum line and dangling between the firewall and the engine:
I guess it wa supposed to be some kind of vent tube, but it wasn't connected to the crankcase, just the vacuum line.
P.S. - this part also had a plunger inside, much like a PVC valve. I don't believe the '54 had a PVC system yet, so I'm pretty sure this part doesn't belong there.
Back in the day, the practice was not uncommon.
Maybe an old guy, who was alive at that time, can tell us why.
There should be two ⅜" bolts, holding a flange to the block, in the area I described. It should either have a 1" (or so) hole, for the tube to "plug" into, or a ⅜" tube, similar to the one on the PCV valve, in your image.
Not from the factory.
Beginning in the late fifties, AC sold a "retrofit" to replace the, often messy, original setup with the more efficient, PCV system.
Norm
Norm
Read the following thread:
https://classicoldsmobile.com/forums...e-madness.html
Then ask me if I care, what you think.
Norm
Norm
It is uncontradicted that General Motors introduced its crankcase ventilation system in September 1960, and has manufactured and sold the same continuously since then. (See Majewski Affidavit (C.T. pp. 20-28) and Exhibits attached.)
With the engine idling at operating temp, remove the oil filler cap. Look for puffs of smoke. If you don't see any, your rings are in good condition. More smoke = more blowby = not good.
And you didn't notice the smell of burning oil, or see smoke from the exhaust, during that time?
Norm
Norm
Where did the vacuum line this thing was attached to go? It would be interesting to see how they had it attached to the block in place of the vent tube.
I'm glad you agree.
Maybe I should have added the part about it being AC or equivalent.
According to the following:
It would be '60 or newer.
Norm
Norm
I just went out and looked at my friends 54 that is in my garage. The vent tube comes from the top and rear of the engine (top is hard to see) and down the right side right in front of the motor support. Near the bottom is a built in filter the is about 2-3 inches thick and about 5 inches in diameter. The filter is not serviceable and can become clogged. We had to have this one cut open and then actuall put brillo pads inside and welded it back up. The pupose of this downdraft tubes (or what anybody else wants to call them) id to carry crankcase emissions down below the car where the draft under the car would keep them out of the interior. With the exception of California, most cars used them until 1963 (I could be off a year on this) when the PCV valve was used. Obviously this was the first emissions control device. Hope this helps.
Here is a pic I took of the vacuum lines on my car:
BTW, Norm and everyone else here - I really appreciate all your help!
Not necessarily! Who ever put that thing on the car might have come up with a PCV from or for an old WW II tank, some of which were still floating around in National Guard units as late as 1960.
1. Massive manifold vacuum leaks (gasket and/or bolt torquing issues)
2. Check valve between vacuum source and booster non-functional or installed backwards.
3. Valve timing way off.
To get things to where it is possible to set engine timing to specs you are going to need to plug all vacuum lines/ports at the engine and set the timing to original factory specs. You have to have a level point of beginning to run tests and without the engine being in time you are just wasting your time.
When it's warm and running, I do see some smoke from the blowby opening on the rear of the motor, not so much out of the oilf iller tube. After the motor's shut off, however, it does smoke for about 10 minutes or so.
Oh yea, it does smoke when it's running, sometimes a lot and sometimes just a little.
Beginning to sound like that old girl needs to be yanked out and rebuilt or at least the heads pulled and refreshed.
very intersting thread.
How hard is it to access the bolts holding the road draft tube/crankcase ventilation tube in place?
I had a '60 TBird that had this tube and I converted it to a closed PCV system. It was much more pleasant to drive without all the fumes.
I'd like to do the same for my '53 Olds but that darn tube is way back behind everything...is there a reasonable way to access it??
thanks,
Casey
thanks,
Casey
#31
I wonder why they would put a filter on the "outbound" side of a ventilation system.
Must have been designed by a "drunken blacksmith".
Same mistake I mentioned earlier:
Any competent mechanic, would have simply removed the tube, cleaned it with solvent, and replaced it.
In addition to hot oil vapors, crankcase gases contain water, acids, and unburned fuel, partially from the fumes that "blow by" the rings during the combustion process.
"Road draft tubes" were used by all manufacturers, to send these "emissions" into the atmosphere. By design, its placement in the air stream, caused a vacuum (only when the car was actually moving) which, in effect, evacuated the crankcase and replaced its contents with fresh air, drawn from the filler/breather cap.
It worked very well, when the car was moving.
At the other end, the breather/filler cap was placed at such an angle, that the fan could "push" air through it, into the crankcase (and out the road draft tube), when the car was not moving.
It did not work as well, but it was better than nothing.
Norm
#32
Line A = Sends manifold vacuum to the inlet of the vacuum pump. Should be another line, sending it to the wiper motor.
Line B = Manifold vacuum for the power brakes = As it should be.
Line C = Vacuum originating from the "ported" source, at the carb, for use with vacuum advance only. The other line should go from the wiper motor to that "other" port on the vacuum pump.
Norm
Norm
#33
Out the exhaust? Driving? Under load?
When accelerating, after slowing down or idling?
Norm
#34
Funny too.
At the top, it's a "slip fit" into the flange, at the rear of the block.
From the bottom, you will see where the tube is attached to the flywheel/starter housing. Remove the bolt and it should come out easily.
Norm
Norm
#35
Yes they do function when a car is just sitting! There is always a certain amount of pressure in the crankcase created by piston movement. If you don't believe that just crawl up under a car having a crankcase vent tube with the engine running and enjoy the vapors puffing out the tube. The performance of a crankcase ventilation tube is indeed enhanced with vehicle forward movement.
#37
#38
I should also note that I got in my leakdown tester that I ordered. I was only able to check the 4 cylinders on the driver's side. On two of them, I got 25% leakage, on the other two it was 40%.
I don't yet know what the cylinders on the passenger side look like yet - I'll try to check them this weekend.
Also, I've taken the car out a few times, driving it around the neighborhood to get it nice and warmed up and to see how it performs after its been running for a while.
It seems to have a pretty bad idle problem. It idles fine when it's cold, but once its warmed up, when you're stopped at a stoplight, the idle will run rough and drop to the point where it will stall if you don't give it some gas. I don't think it's a carb problem as I just put a factory rebuilt carb on it about a week ago and I was having similar problems with the old carb.
#39
Was the rebuilt carb from a parts store or done by a rebuilder? I have had HORRIBLE luck with parts store rebuilds. They are junk.
As for the road draft tube, though the topic has been beaten beyond recognition, does effectively evacuate the crankcase at idle. All my knowledge of them are on mopars, but the theory of how they work is the same. + Pressure evacutes the crankcase, in motion there is a low pressure area below the tube making it easier to evacuate. Do olds road draft tubes have a small square of sheet metal on the front (at the bottom) to create more of a vacuum? (Low pressure area)
On a mopar, the air is deflected off the sheetmetal below the tube and creates a low pressure area (boyle's law, the thing that makes aeroplanes fly)to use the + pressure of the crankcase to push the gases out the tube. I'd suppose it couldn't be much of a different principal.
#40
I really hate to say this, but with a constant light gray or bluish gray emission from the tailpipe and the results you got from the leak down, the engine needs a major rebuilding, which may require boring the cylinders. It is for certain the heads need a major rebuild and there is no reason to do that and put them back on when it appears you have one or more cylinders that are no longer true. If you haven't already you should do a compression test on all cylinders. I suspect the results of a compression test are not going to be good, unfortunately.
