Cam question
Old May 5th, 2015, 10:04 PM
I'm indecisive. Or am I..
Napoleon Solo's Avatar
Cam question
Is there a point to putting a slightly lumpier cam in my 64 330 If I do nothing else? I want to keep stock intake/heads and use thornton exhaust manifolds. If it's acceptible, which cam?
Napoleon Solo is offline
Old May 5th, 2015, 10:53 PM
Do you know if your engine is the high compression or the low compression version? I don't know the specs on that year cam, but there is usually some room for improvement over most factory cams. You can't go too much larger without the risk of over-camming the engine, so you need to know the factory specs so you have a starting point for determining how big is too big.
Fun71 is online now
grmchne78
June 25th, 2015 06:23 PM
Oldsmaniac
June 20th, 2014 05:44 AM
Uncle Hulka
March 12th, 2014 03:41 PM
GoldOlds
March 16th, 2008 06:58 PM
glb1948
August 23rd, 2006 08:10 AM
Quick Reply: Cam question
