Anyone run a Comp Cam roller like the XR262HR (42-413-9)?
Old June 1st, 2011, 09:03 PM
oldzy's Avatar
Just wondering if anyone has run a Comp Cam roller like the XR262HR (42-413-9) or similar and opinions. I will be running a basically stock 350 engine/exhaust w/duals, with 3.42 gears and aiming for ~9:5.1 CR.
Footnote #5 @ http://www.compcams.com/Company/CC/c...csid=1182&sb=2 of this cam says the valve springs 'require machining on cylinder heads'. What does that mean exactly? I am considering a roller cam like this, the Harland Sharp roller rockers (pedestal mount most likely to avoid head machining and less height clearance issues), but don't understand what the footnote #5 is talking about.
oldzy is offline
Old June 2nd, 2011, 05:17 AM
507OLDS's Avatar
Some Oldsmobile heads have shallow spring pockets,and some have deeper spring pockets.You won't know if or how much to machine until you have the valves mocked in the head,and the installed height of the spring is determined.
507OLDS is offline
Old June 2nd, 2011, 05:27 PM
Warhead's Avatar
X2 what Brian said.
Earlier #5 heads will usually set up around 1.700" after the valve job, hence the disclaimer.
Your Number 7a heads should be near 1.800", once the valve rotators get replaced with real retainers. There is more room for springs with these heads, and that is what they are gearing toward.
Have your machinist measure first.
Jim
Warhead is offline
Old July 22nd, 2011, 08:34 PM
oldzy's Avatar
Just bumping to see if anyone has used a hyd. roller cam with similar specs to the XR262HR above. thx
oldzy is offline
Old July 29th, 2011, 12:24 AM
oldzy's Avatar
oldzy is offline
shamusj
March 4th, 2016 06:48 AM
oldzy
May 13th, 2012 11:59 AM
Chesrown 67 OAI
June 22nd, 2011 06:03 AM
geckonz08
February 24th, 2010 12:56 AM
MN71W30
June 23rd, 2009 07:24 PM
Quick Reply: Anyone run a Comp Cam roller like the XR262HR (42-413-9)?
