350/350 in a 65 cutlass
Old August 29th, 2008, 07:59 AM
65cutty's Avatar
Wink 350/350 in a 65 cutlass
my cutlass has a 330 4bbl w/a jetaway in it now and with parts getting hard to get as each year goes by am thinking a 350/ 350 trans from a 1974 cutlass doner car, what problems would I be facing ? if any and maybe an anwser to solve them. thank you all for a great olds site..... jim
65cutty is offline
Old August 29th, 2008, 09:18 AM
442scotty's Avatar
shifter linkage is no problem..bolts right up....if the 350 has a convertor clutch you will have to transfer the cable and bracket assembly..I think I did one a few years ago with no problem...and play with wiring for the convertor lockup....cant recall aout the length of the trans and using the same driveshaft..
If you are feeling up to it and want better mileage try a 200R4...thats what I have in mine...I think you have to either shorten or lengthen the driveshaft and move the crossmember back a little bit(mine didnt have the original trans so I had to lengthen my driveshaft)...and of course transfer the convertor clutch cable linkage ...lockup wiring...
442scotty is offline
Old August 29th, 2008, 04:53 PM
This is a complete bolt-in. One of the easiest swaps ever.
joe_padavano is offline
Old September 3rd, 2008, 06:42 PM
harleyrules's Avatar
Joe,
Would this also be a simple bolt up system for a 64 Cutlass too?
harleyrules is offline
Old September 3rd, 2008, 07:13 PM
Wasted's Avatar
Originally Posted by harleyrules
Joe,
Yes it would. Im doing the same swap right now into my f-85.
Wasted is offline
Old September 4th, 2008, 08:43 PM
Wasted,
Let me know how it goes and if you run into any problems.
Old September 4th, 2008, 10:29 PM
Wasted's Avatar
I just got the transmission bolted up and so far no problems at all. Hopefully Ill find time to put the engine in within a couple of days, and Ill let you know how that goes.
Wasted is offline
Old September 9th, 2008, 08:42 PM
Any updated info? How is the project coming along?
Old September 10th, 2008, 03:33 AM
65cutty's Avatar
TCI
Ive decited to go with the TCI transmission, th350, mild shift, finding someone that rebuilds and will back there work is risky.
65cutty is offline
Old September 10th, 2008, 06:33 PM
Wasted's Avatar
I tried working on it a few times this week, and mother nature just didn't want me to. Every time I went to work on it I would get in a good 20 minutes at most and it would start to storm pretty hard. Man I need a place to work inside
Wasted is offline
Old September 12th, 2008, 09:34 PM
Wasted's Avatar
I finally got the 350 in today with the help of my dad and some friends. There wasn't any problems at all , just took a little time lining up the mounts.
Wasted is offline
Old September 22nd, 2008, 09:07 AM
Toliver
77 oldsMAbrotha's Avatar
I just found a 330 crank; no flexplate Interested in parting with yours, maybe?
77 oldsMAbrotha is offline
Old September 23rd, 2008, 12:22 AM
64Rocket's Avatar
"Harlyrules" if you are useing stock manifolds no problem. If you plan on headers you will have to move the engine back 1 inch. Which means redrill the frame mounts and redrill the trans cross member.
Gene
64Rocket is offline
Old September 23rd, 2008, 12:32 AM
Wasted's Avatar
Gene
Do you have headers and is that what you had to do? Im asking because in the future I want to put headers on it and I read that 65-67 headers will work. I would just have to use a mini starter
Wasted is offline
Old September 28th, 2008, 06:13 PM
Interesting
dharlett
June 26th, 2013 08:49 PM
QS442
November 30th, 2011 05:45 PM
halfmoontrail
Drivetrain/Differentials
July 1st, 2011 09:08 AM
dharlett
September 23rd, 2009 03:30 PM
jd75
June 1st, 2009 01:56 PM
Quick Reply: 350/350 in a 65 cutlass
