330 intake manifold and carburator
Hi!
I read almost all threads but did not find the right answer for my issue!
What intake manifold and carburator fits best on my ´66 330 holiday coupe and has the best performance?
What do I have to change when build in a new manifold and a carburator, or is it plug and play!
Sorry because of my english, I´m not a native speaker.
Thank you very much!
An engine is a system and all parts need to be matched to the intended purpose for best performance.
I´m looking for street driveability and i´m looking for about 350HP. Yes to dual exhaust and I have the shitty 2 gear transmission (will change to 4 gear automatic transmission).
And the motor will be reworked before (original). Is now a answer possible?? i hope so.
thanks a lot
thanks a lot
Yup. I'm assuming this is in a Cutlass. I'd use an Edelbrock Performer RPM (P/N 7111) and a properly set up Quadrajet carb. A 600 CFM E-brock carb would work also, but I think there are some linkage clearance issues that require a spacer.
http://www.summitracing.com/parts/edl-7111/overview/
He will already have a Qjet, but it will need an overhaul and jet change. A RPM intake as suggested plus the new Street Demon carburetor. This carb is based off the Carter Thermoquad. You can get complete tuning kits and secondary air door adjusts with a screw driver. The Thermoquad needed a special tool. You can get either a polymer or aluminum main body, optional tps for use with trans like the 4L60E. It is 625 cfm and fits square and spread bore manifolds.
vikingharley
February 14th, 2021 05:57 AM
celodog
December 30th, 2012 10:13 AM
