1967 330 rear main seal fixes
Old July 27th, 2013, 03:47 PM
pbarney's Avatar
I have a 67 330 hi comp. with a slight rear main bearing seal leak. The factory service manual discribes a fix leaving the engine in. It requires servicing the upper part of the worn seal by punching it further in the block and butting short pieces of the old bottom seal to fill the upper grove. I wonder of this really works. Anyone have experience with this fix.
I have health issues and do not cherish the thought of pulling the motor for this quarter size oil leak.
pbarney is offline
Old July 27th, 2013, 08:21 PM
Out of Line, Everytime😉
olds 307 and 403's Avatar
I say live with it. You could try it but may make it worse. The only really good fix is replacing the rope with a neoprene seal.
olds 307 and 403 is offline
Old July 27th, 2013, 08:30 PM
You can replace the seal with the engine in the car, but it is FAR easier to leave a pie tin under your parking space and ignore it.
This problem is definitely categorized under "Don't sweat the small stuff."
MDchanic is offline
Old July 27th, 2013, 09:19 PM
I prefer cardboard, I don't sweat the minor leaks either. If an old engine or trans don't leak it's broke.
oldcutlass is offline
Roan
August 7th, 2014 10:52 AM
Redog
Alero
April 8th, 2012 08:51 AM
odie
November 27th, 2010 07:30 PM
65cutty
September 23rd, 2008 10:07 AM
gearheads78
April 17th, 2008 05:03 PM
Quick Reply: 1967 330 rear main seal fixes
