Royal Purple Raceway - 25 May 2012 (Video)
Old May 26th, 2012, 03:14 AM
ah64pilot's Avatar
What a night! Danny and Tom (70Wcars and sicky olds) drove all the way to Houston from San Antonio! Man, you guys are awesome! I had a blast!
So after a long anticipated return to the track, we figured out our fuel issue and are running on all 8 cylinders thanks to Harland Sharp. The car performed well and gave us a direction for furthered improvement...suspension!!!
After 2 consecutive 12.2- passes we let the cars cool down for a bit and I pulled a 12.11 @ 112.55 mph. Unfortunately, I forgot to record the first two runs on the Go-Pro so all you get is the last video, which happens to be the best one anyway lol! Enjoy!
http://youtu.be/czV0ry_XSX4
Royal Purple Raceway 25 May 2012 Oldsmobile Beatdown
ah64pilot is offline
Old May 26th, 2012, 04:15 AM
380 Racer's Avatar
380 Racer is offline
Old May 26th, 2012, 08:10 AM
Rickman48's Avatar
Sounded quite effortless - good job!!
Rickman48 is offline
Old May 26th, 2012, 08:51 AM
ah64pilot's Avatar
I am stoked, I can't wait to get either the QA1 coil over set up or the Moroso trick springs w/ 90/10 shocks. That should get us into the 11's, then we'll change the 3.42 out for a 3.90 and see what we get. New (lighter) wheels and tires should help some too...
The best part of it is, my wife wants to see the car go faster more than I do so funding shouldn't be a problem And she had a blast thanks to Sicky and his girlfriend so apparently she is already planning a trip to San Antonio (River City Raceway)...I guess if she twists my arm I'll go
Old May 26th, 2012, 09:01 AM
Rickman48's Avatar
As said to my Nephew, [492 '69 - no pass yet] better do the math!
Last thing you want to do is overrev an Olds!!
RPM's through the traps??
He has a 3:55 12-bolt.
Old May 26th, 2012, 09:21 AM
ah64pilot's Avatar
I was barely hitting 5000 at the traps...if you watch the video you can see the shift lift almost kick on well after the traps & it was set at 5300. I think we'll be ok with 3.90 gears...the rev limiter is set at 6000.
I'm using the 8.5 Corporate rear end with 3.42 gears. I'll swap over to some Moser axles and a detroit locker when I change the gears out.
Old May 26th, 2012, 09:33 AM
joesw31's Avatar
This is awsome Steve! I like the 12.11 pass! It was so hot and humid on those runs. If it was cooler and less humid you would have had an 11 second run. But we have the Houston heat and humidity to contend with.
Next, a gear change, and the front suspension as we spoke about and you will see some solid 11 second runs!
joesw31 is offline
Old May 26th, 2012, 09:42 AM
ah64pilot's Avatar
Joe, I know! I can't wait! I really wish you could've made it out last night, it was so fun! Maybe next time
Old May 26th, 2012, 02:39 PM
70Wcars's Avatar
Steve...great time last night...and Sicky...maniacle road trip!!!
I had a blast...especially when the " drunk " walked up to my car and stared at the 442 on the fender then said " those numbers mean something...right??!! "...lmao.
Your car is sweeet Steve..we will get some 11's for you. Pleased with how my hot rod handled the humidity. If you can post it I would love to the the vid of my last pass..
The dude in the middle in the pic does NOT have a Mil Spec hair cut...lol
Danny
70Wcars is offline
Old May 26th, 2012, 02:48 PM
ah64pilot's Avatar
Danny, I'll get it posted...I didn't have time to edit the video and get it uploaded...we had to run to Nacogdoches for a wedding today. I'll get it up tomorrow. Its a great run!
Steve
Old May 26th, 2012, 08:13 PM
SBORule's Avatar
Good to see it running good and you all having fun.
Those GoPro cameras are cool. Wish I knew about them before I bought my Sony HDR CX-160 recently. I could of bought two GoPro's and be shooting 3d video's, the only drawback is you have to wear red/blue 3d glasses instead of the tinted ones you wear to watch real 3d video. It also can take time lap video which is cool too. And I like that water tight case you can put it in for under water videos too.
Look at me, I'm rambling on about your camera instead of your car.
SBORule is offline
Old May 26th, 2012, 08:29 PM
Chevy budget Olds powered
coppercutlass's Avatar
killer vid glad to hear she is running great.
coppercutlass is offline
Old May 27th, 2012, 07:32 AM
FAZ442's Avatar
Great video.
Where did you get that guage that tells you when to shift and how many rpms did you have it at?
FAZ442 is offline
Old May 27th, 2012, 10:10 AM
70Wcars's Avatar
Hey Faz it's a Shift Light. Look in Jegs or Summit. I think Steve had his set at 5300...mine at 6500 in the 10 sec car and 7100 in the 9 sec. ride. Higher rpm builds including better flowing Heads and Intakes, bigger Carbs and Cams and of course a VERY light weight rotating assembly and modified/reinforced bottom ends in those two cars.
Danny
70Wcars is offline
Old May 27th, 2012, 10:20 AM
ah64pilot's Avatar
Faz, as Danny said its a shift light. The one I have is an Autometer digital RPM shift light. It tells you the rpm like a tachometer and is programmable for custom shift points. The one I have sets a single point but you can get them for up to 3 separate shift points.
It also has a peak rpm recall feature that let's you see what the highest rpm was on the run. They start at $150 and go up from there.
Old May 27th, 2012, 02:37 PM
FAZ442's Avatar
Very Nice... Will look into getting one.
FAZ442 is offline
Old May 27th, 2012, 04:38 PM
ah64pilot's Avatar
Alright guys, here is the stand video of the night's runs. I'm sorry Danny, I left the first pass in there because I had a good run...I am rather proud of that .036 light I cut LOL! Enjoy!
Old May 27th, 2012, 05:11 PM
NôôB
sicky olds's Avatar
Maniacal would have been driving to Houston and back by myself in the H/O lol. Thanks to Lizz playing hookie we were able to suprise Stephen,too bad Lizz wouldnt let me run her focus down the track LOL. Def Had a blast!!!!! Cant wait to hang out again. Will post pics later when i get my camera back...
sicky olds is offline
Old May 27th, 2012, 05:26 PM
ah64pilot's Avatar
Boy was I surprised too! Thanks for making my night! And Lisa really enjoyed hanging out with you and Liz...she's already talking about making a trip to San Antonio lol!
Old May 27th, 2012, 05:29 PM
NôôB
sicky olds's Avatar
NICE!!!!! Cant wait...
Old May 27th, 2012, 06:45 PM
joesw31's Avatar
Hope to be next time. However, I understand Sealy is next? Sicky, gonna bring the HO?
joesw31 is offline
Old May 27th, 2012, 07:37 PM
NôôB
sicky olds's Avatar
Have to see the distance on that one lol. If it was the track in marian then i would say sure. Sold my DD so it is my only means of transportation right now lol
Old May 27th, 2012, 08:30 PM
ah64pilot's Avatar
I'm down for a trip to Sealy...let me get my front suspension finished and we'll be there. I think I'm gonna go ahead and spring for the QA1 setup, I just like the idea of having such an adjustable setup.
Old May 28th, 2012, 05:02 AM
joesw31's Avatar
Steve, A set of 90/10 up front and a set of 50/50 shocks in the rear. Change the big sway bar you have up front. Good alignment, and some good tires upfront,
joesw31 is offline
Old May 28th, 2012, 05:04 AM
joesw31's Avatar
Sicky, what gear does your HO have?
joesw31 is offline
Old May 28th, 2012, 07:03 AM
NôôB
sicky olds's Avatar
Not really sure but probably the 3.23 gears it came with lol.
Old May 28th, 2012, 01:23 PM
joesw31's Avatar
Those are highway gears... I guess I'll it at Sealy...Lol
joesw31 is offline
Old May 28th, 2012, 01:56 PM
Looked like a blast!!! Nice videos!
oldcutlass is online now
Old May 28th, 2012, 02:13 PM
ah64pilot's Avatar
Sicky, when I change out to the 3.90's I'll give you the 3.42 Richmond's I have in it now. If you want to change them that is...
Old June 9th, 2012, 03:24 PM
Paul Dodd, 10 sec Old's
Paul dodd's Avatar
Quest for the 11's
Great to see you back on track Pilot, great footage. Your 112mph is exact same as my Olds and as my best time is 11.83 you should have no probs getting into the 11's soon. Just for comparison i also still use a 10 bolt with 3.73 gears, detroit locker and mark williams 30 spline axles. I would recommend a 3.73 gear as opposed to one in the 3.9s as you may find it a bit much for highway driving and with our torque you dont need that much gear. I shift at 5300 where my peak hp is. Dont know what converter you got but i use a 10 inch with 3000 stall. My best 60ft is 1.53 with stock front suspension but am fitting some moroso trick springs soon, pn 47160, but adjustable shocks sounds a better idea i just went for the cheap option. Good luck next time out, i raced recently but could not get grip out of M/T drag radials with Nitrous on a poor track. Oh well will try again at the better track, Santa Pod, in July and hope it hooks with the new springs otherwise its back to slicks to try and beat my pb on Nos 10.73@125mph, cheers, Paul, U.K.
Paul dodd is offline
Old June 9th, 2012, 03:27 PM
  #31
NôôB
sicky olds's Avatar
na its ok but i might know someone who might want them.... i will hit you up on textuses
63super88
September 14th, 2014 07:16 PM
ah64pilot
June 18th, 2012 08:49 PM
ah64pilot
May 21st, 2012 09:17 PM
ah64pilot
April 12th, 2012 09:19 PM
slumpy
August 1st, 2009 03:03 PM
Quick Reply: Royal Purple Raceway - 25 May 2012 (Video)
