Dr. Dan's 478
Old February 3rd, 2021, 06:19 PM
  #281
VORTECPRO's Avatar
[QUOTE=Dan A. Macal;1315866]I have never ran any power adders on any of my stuff EVER. my 66 F 85 ran 9.60`s leaving from a dead idle 373 rear gear and I drove it to work several times. NO electronics, trans brake-NOTHING. When you get done with class racing, maybe you can graduate up to bracket racing. and if you think it`s easier than class racing....show up at the world footbrake challenge in Bristol TN in July. I bet you can`t get past 2 rounds. Everything I ever ever raced, I`ve won in. I just went through all my trophies moving. 296 total wins. 98 with 1 car. Ya know what.....you wouldn`t make it past 2nd round at a normal saturday night bracket race. I like class racing.....atleast until I found out you do it.[/QUOTE
Got it, what did you say that thing weighed? You could be right about the bracket racing, either I do very good or very bad. I don't claim to be a bracket racer, but I do drive and race 9 and 8 sec full weight small tire NA street cars, some with production GM engines. The NA race cars are faster
Can you post some pictures of this "66"
VORTECPRO is offline
Old February 3rd, 2021, 06:21 PM
  #282
HighwayStar 442's Avatar
See what i mean!
HighwayStar 442 is offline
Old February 3rd, 2021, 06:23 PM
  #283
VORTECPRO's Avatar
Originally Posted by HighwayStar 442
Its one thing when I get into it with Dan or Duh, they have actually done something, Dan a hair more than Duh, but you have done absolutely nothing, and that car of yours is a disgrace. Thats why I rarely comment on anything you would post.
Old February 3rd, 2021, 06:24 PM
  #284
Love you too!
Old February 17th, 2021, 08:48 PM
  #285
propjoe's Avatar
Dan,
Is there any numbers for torque below 4700 rpm?
What a beast!!!
propjoe is offline
Old February 18th, 2021, 02:43 PM
  #286
cutlassefi's Avatar
Originally Posted by propjoe
Dan,
What a beast!!!
I can answer that. Bill didn’t make any pulls lower than that for whatever reason. I agree that It would’ve been nice to see what it made down around 4000 or so.
cutlassefi is offline
Old February 18th, 2021, 03:47 PM
  #287
VORTECPRO's Avatar
The reason Bill didn't pull it lower is because if a person was to utilize the BT engine to its full potential it would never even see 4700 RPM on a run down the track, plus starting the pull higher would be easier on the mains.
Old February 18th, 2021, 04:00 PM
  #288
cutlassefi's Avatar
But how would you know that unless you pulled it down that far. You throw out the first and last couple of numbers anyway.
If you think peak tq occurred at 4500 you’re a bigger Dyno idiot than I thought. Unless you pull it beyond the initial high points you really don’t know everything you need to.
Old February 18th, 2021, 04:04 PM
  #289
VORTECPRO's Avatar
Pretty sure you'd want the converter to flash around 5200 RPM with that combination.
Old February 18th, 2021, 06:24 PM
  #290
propjoe's Avatar
That would make an absolute wicked jet boat engine with the right pump... Lots O Grunt down low.
propjoe is offline
Old December 14th, 2021, 02:33 PM
  #291
fatjack2's Avatar
Looking to do the same thing for my '69 442. What was the final cost, ballpark? Thanks.
fatjack2 is offline
Old December 14th, 2021, 03:02 PM
  #292
cutlassefi's Avatar
A lot, a whole lot.
Old December 14th, 2021, 03:43 PM
  #293
Rallye469's Avatar
A lot, a whole lot.
Thats pretty accurate I'd say.
​​​​​​​-peter
Rallye469 is offline
Old December 14th, 2021, 03:46 PM
  #294
fatjack2's Avatar
Much appreciated. An that's the perfect answer, beother.
fatjack2 is offline
Old December 14th, 2021, 06:27 PM
  #295
DR_DAN's Avatar
[QUOTE=fatjack2;1390370]Much appreciated. An that's the perfect answer, beother.[/QUOTEi
if you have serious money, pm me. I’ll sell it.
DR_DAN is offline
Old December 15th, 2021, 05:00 PM
  #296
CANADIANOLDS's Avatar
Did this race happen yet? 😁
CANADIANOLDS is online now
Old December 15th, 2021, 07:40 PM
  #297
propjoe's Avatar
This is a fantastic Olds engine. If only there were solid main 403 blocks. Dan's engine proves out what I was hoping for as far as potential of the hated 403. Is there a "light" version of Dan's 478 that started as a 403? I already have a nice 403 in my car, but looking to an upgrade, defiantly not to the extent Dan has done. Good heads, stroker crank, roller cam... I know the crank is a huge piece of the puzzle, but is there a way to keep the block in one piece? Care to share? Dan, Bill, Mark???
TIA
propjoe is offline
Old December 16th, 2021, 03:43 AM
  #298
DR_DAN's Avatar
TIA
the only way to do it is a 1 piece billet girdle. Not a J&S bolt together
DR_DAN is offline
Old December 16th, 2021, 03:51 AM
  #299
VORTECPRO's Avatar
Old December 16th, 2021, 04:46 PM
  #300
I can’t wait for it
Old December 16th, 2021, 05:20 PM
  #301
Thats nice build. After some research these 403s have been successful in NHRA stock eliminator which you cannot use a girdle.
you actually think a dry sump 463 inch 11.3 to one making 1.49 per cube is nice?
With a solid roller, .776” lift
Old December 17th, 2021, 05:07 PM
  #302
propjoe's Avatar
Thanks Dan, figured that.
I guess I need to ask Bill about the billet piece $$$ for another.
Keep up the good work.
Edit: We do have two 5 axis CNC and 1 three axis CNC milling centers at work now.
propjoe is offline
Old December 25th, 2021, 08:05 PM
  #303
DR_DAN's Avatar
TIA
hey joe, ask mark about the 403 I did I got all the parts from mark. 9-6-1 hydraulic roller on 91 pump gas 470/494 then mark recalibrated his dyno he’ll have to tell you the rest. Affordable build
DR_DAN is offline
Old December 25th, 2021, 08:25 PM
  #304
propjoe's Avatar
hey joe, ask mark about the 403 I did I got all the parts from mark. 9-6-1 hydraulic roller on 91 pump gas 470/494 then mark re-calibrated his dyno he’ll have to tell you the rest. Affordable build
Merry Christmas Dan and Thanks. I'll get a hold of Mark.
At some time we need to have to get together for a beer or three. I may move to Florida at some point. State of ILL is just that. ILL. Im looking north of you though. We need to talk...
propjoe is offline
Old December 25th, 2021, 10:15 PM
  #305
DR_DAN's Avatar
I just moved to Georgia due to a job offer. I miss Florida terribly but do like it here.
thinks to do in Illannoy- leave
DR_DAN is offline
Old December 25th, 2021, 10:58 PM
  #306
Chevy budget Olds powered
coppercutlass's Avatar
People complain about Illinois blahhhhh . I got 4 drag strips within 100 miles appx . From where I live ., Silver linings lol.
coppercutlass is offline
Old February 6th, 2022, 10:07 AM
  #307
propjoe's Avatar
Originally Posted by Bernhard
Nice
Look forward to seeing more pics.
Bernard, I posted a link to a but load of pics of the little Lycoming I did in the major projects and builds section.
Edit: Moved to the clubhouse?
propjoe is offline
Old February 6th, 2022, 12:17 PM
  #308
DR_DAN's Avatar
yup. You and I discussed it and think peak torque is probably 3800-4000 and more towards 660 tq.
DR_DAN is offline
wr1970
October 5th, 2019 07:52 AM
Oldsragger
February 9th, 2018 08:38 PM
cutlassefi
May 3rd, 2017 06:03 AM
dman0712
June 18th, 2010 07:41 AM
VITO
June 26th, 2007 09:34 AM
Quick Reply: Dr. Dan's 478
