Dr. Dan's 478
Old January 14th, 2020, 04:43 PM
cutlassefi's Avatar
Dr. Dan's 478
Dan and Bill have already posted this on FB but thought I'd put it here as well.
403 block with one of my 4.00" stroker cranks. BTR built with BTR Girdle and BTR ported Edelbrocks. Port matched Victor, 850 QF, 10.7:1, hyd roller running solid roller lifters. Not bad for a "Small Block" Olds huh?
cutlassefi is offline
Old January 14th, 2020, 04:47 PM
Awesome Mark.
oldcutlass is offline
Old January 14th, 2020, 04:51 PM
edzolz's Avatar
Great numbers, but how long will the 403 block last at that RPM? I know it is girdled and all but 6500?
edzolz is offline
Old January 14th, 2020, 04:59 PM
cutlassefi's Avatar
With the full girdle and a really strong and stiff crank it'll be fine. Bill thought enough of the rod and crank combo to want to take it to 7K. But it quit making power before that anyway so...
This crank is lighter, internally balanced, and about 30% stronger than a 330 crank. That helps everything.
Old January 14th, 2020, 05:42 PM
allyolds68's Avatar
What was the water temp?...... sorry Mark, I couldn’t resist....lol.
allyolds68 is offline
Old January 14th, 2020, 06:03 PM
cutlassefi's Avatar
😉Dunno, dynoed at BTR. But I’ll bet it was cool😎 . However he will drive it some but mostly track so he can cool it down to make comparable numbers.
Old January 14th, 2020, 06:16 PM
59-59-59's Avatar
I would like to see the final cost of everything to make those numbers
59-59-59 is offline
Old January 14th, 2020, 06:24 PM
Thanks for posting here. I would have never seen this otherwise as I am one of the folks who aren't on fb.
Fun71 is offline
Old January 14th, 2020, 06:56 PM
VORTECPRO's Avatar
Question
Thats the Olds combo I would build, but the block would be filled, nice work Bill. Sure like to see all the data. 478 inches, big bores make power.
VORTECPRO is offline
Old January 15th, 2020, 08:37 PM
olds403's Avatar
Quite impressed coming out of BTR. His dyno...nuff said.
olds403 is offline
Old January 16th, 2020, 11:10 AM
rfpowerdude's Avatar
That has to be the best HP out of a 403 yet.
Congrats Mark, Bill and of course, Dan M.!
rfpowerdude is offline
Old January 16th, 2020, 02:23 PM
wr1970's Avatar
Good read thanks for posting.
wr1970 is offline
Old January 16th, 2020, 03:13 PM
cutlassefi's Avatar
Apparently they weren't done yet So much for a smaller carb making more low end power huh guys? That's a farce more often than not. It picked up everywhere with the larger carb.
Old January 16th, 2020, 05:24 PM
fleming442's Avatar
Holy smokes! Glad to see Bill hasn't completely abandoned us.
fleming442 is offline
Old January 16th, 2020, 05:29 PM
Out of Line, Everytime😉
olds 307 and 403's Avatar
Look at the torque and horsepower this thing makes.
olds 307 and 403 is offline
Old January 17th, 2020, 06:43 AM
oddball's Avatar
Mark, dish with the details, man! Piston dish? Head cc? Lobe profile?
oddball is offline
Old January 17th, 2020, 08:06 AM
OLDSter Ralph's Avatar
That must be a helluva girdle on that 403.
OLDSter Ralph is offline
Old January 17th, 2020, 09:42 AM
cutlassefi's Avatar
Cam was spec’d by Bill but I know it’s a Comp hyd Roller, 242/248@.050 on a 108lsa. Bill uses that cam in a lot of stuff.
Pistons were custom CP’s, dish was enough to make 10.7:1 with 70cc heads. Valves were 2.160/1.68.
Could've used more cam for sure, or at least a wider lsa imo.
Old January 17th, 2020, 09:56 AM
cutlassefi's Avatar
No you don't😉.
Old January 17th, 2020, 11:13 AM
1arunem's Avatar
Stout!!
1arunem is offline
Old January 17th, 2020, 11:43 AM
Kennybill's Avatar
The final cost would give one, "heart pulpatations." I'd shift it at 5,400 and let it run trough the traps at "whatever" but that's just me. Lighter the car the better.
Kennybill is offline
Old January 17th, 2020, 06:29 PM
VORTECPRO's Avatar
No one should be surprised, I've never liked the small bore, long stroke 455 combination. The 403 block gives you a 4.351 bore standard, opens up to take a big intake valve, short stroke, small main journal, combined with a ported aftermarket head that will make power past 5200 RPM. 484 inches, big bore, solid roller, aftermarket heads, I would expect this kind of power. Does any one know if the block was filled? Measured HP was 630.
Old January 17th, 2020, 06:33 PM
Would that even do anything to support the windowed mains and keep the crank attached to the block?
Fun71 is offline
Old January 17th, 2020, 06:40 PM
VORTECPRO's Avatar
Filling the block won't hurt, be interesting to see what it does at the track. That thing does look fragile.
Old January 17th, 2020, 06:45 PM
VORTECPRO's Avatar
You mean you wouldn't leave @ 5800 RPM on the trans brake.........
Old January 18th, 2020, 06:09 AM
No. The filling is above the main webs. More to the point, the epoxy used to fill the block is considerably less stiff than the cast iron, so no load gets transferred. In the same way that electrical current takes the path of least resistance, load is always transferred through the path that is stiffest.
IF (and that's a big "if") filling the block helps minimize or damp cyclical deflections and thus mitigate fatigue loading and crack propagation, then there MIGHT be a minor benefit, but don't count on it. As Mark noted, there's a full girdle. This is what increases the stiffness and strength of the bottom end. And don't confuse "strength" with "stiffness". They are two different load cases that frequently require different structural solutions.
joe_padavano is offline
Old January 18th, 2020, 06:53 AM
Old(s)GuysRule
67OAI's Avatar
Do I dare bring up mention of the Chrysler 392 hemi? That was a window main block that was raced by many top gas and top fuel racers and held together because of the girdle and the fill; many were used in tractor pull as well, and these motors had a roots blower on top. Kudos to ya Dan. Anxious to see how she performs!
67OAI is offline
Old January 18th, 2020, 09:29 AM
I for one was unaware the 392's had a windowed block. They were cast in a different era when engine weight wasn't a factor. It doesn't surprise me that they used a girdle back then. I am sure the 371 and 394 Olds engines also had a girdle. Obviously, a girdle is a major benefit to reliability and power output.
IF, a stout girdle and crank could be manufactured at a "fairly reasonable" cost, 403's could become more popular. The bore size of the 403 has always been attractive, but the windowed mains have been the weakness. If Oldsmobile had cast a strong block in the 403, they could have upped the displacement "strokers" and we could have had a monster 442 engine.
......Just my two cents worth.
Old January 18th, 2020, 11:44 AM
Bernhard's Avatar
WOW
Congrats to DR Dan and Bill.
Congrats to Mark on your stroker crank making its way in to this stout build.
Are they running aluminum rods?
Bernhard is offline
Old January 18th, 2020, 11:58 AM
Bernhard's Avatar
Mark do you know if the block went through cryogenic process?
Bernhard is offline
Old January 18th, 2020, 12:05 PM
  #31
cutlassefi's Avatar
No it did not and no block fill. Rods are Eagle I beams with the big bolts.
Old January 18th, 2020, 02:40 PM
  #32
cutlassefi's Avatar
No. The filling is above the main webs. If people were a bit more observant they would see the cyl skirts on a 403 go below the rest of the block, hence block fill would have minimal value in relation to main web stiffening as Joe said. More to the point, the epoxy used to fill the block is considerably less stiff than the cast iron, so no load gets transferred. In the same way that electrical current takes the path of least resistance, load is always transferred through the path that is stiffest.
IF (and that's a big "if") filling the block helps minimize or dampen cyclical deflections and thus mitigate fatigue loading and crack propagation, then there MIGHT be a minor benefit, but don't count on it. As Mark noted, there's a full girdle. This is what increases the stiffness and strength of the bottom end. And don't confuse "strength" with "stiffness". They are two different load cases that frequently require different structural solutions. Correct, anyone ever seen how they test airplane wings, scary!
I have a pic of the girdle as it was installed. I'll try to find and post it. With that said this was a great leap for the 403. As I've said before, the Olds small block ain't dead.
Old January 18th, 2020, 04:13 PM
  #33
Bernhard's Avatar
I think for a short period after the Rocket aftermarket block became available the general focus was on this amazing block.
The small block will always have its fan base. I still think the 350 is Oldsmobile's best engine design from the era that made it to production.
I hope DR Dan's build can hold up to track use like his other builds.
Bernhard is offline
Old January 18th, 2020, 04:23 PM
  #34
VORTECPRO's Avatar
Its too bad they windowed the mains like that, I always had my eye on that block until someone pointed out the main saddles. The more I look at that 403 block, the more I think those windows can be welded up,
Old January 18th, 2020, 06:51 PM
  #35
Bernhard's Avatar
That would be a cool build.
There was a RealOldsPower member that built a one piece lower block support that was very cool it also survived the dyno pulls.
I don't know what happened to that build.
I hope Dan's build lasts as long as his other 403 builds.
The question for the small block fans is does it make sense to build a stroker DX or Nascar block with a smaller bore.
I think the reason Dan built the 403 is because he has had success and is also big supporter of the engine. He took a lot of flack from the haters for his engine choice at one time.
Bernhard is offline
Old January 18th, 2020, 08:21 PM
  #36
Bernhard's Avatar
Cage 403
Here is the 403 with a Cage
http://www.mondello.com/page8.html
Bernhard is offline
Old January 19th, 2020, 09:12 AM
  #37
VORTECPRO's Avatar
Thats nice build. After some research these 403s have been successful in NHRA stock eliminator which you cannot use a girdle.
Old January 19th, 2020, 10:39 AM
  #38
Bernhard's Avatar
The 403 has set records in Stock and has been hit many times.
Very well know Oldsmobile racer from WA state.
This car has set records and has moved from stock to super stock
http://classracer.com/classforum/showthread.php?t=59390
Bernhard is offline
Old January 19th, 2020, 11:11 AM
  #39
Kennybill's Avatar
dedicated, nice read.
https://www.rentonreporter.com/sport...ing-track/?amp
Old January 19th, 2020, 05:12 PM
  #40
Kyle's77cutlass's Avatar
Jesus the power out of that is insane!!!!
Kyle's77cutlass is offline
Quick Reply: Dr. Dan's 478
