Double adjustable shocks for drag racing
Old December 6th, 2020, 03:19 PM
oldsmoboogie's Avatar
I知 looking to upgrade the 72 this winter in preparation for the spring racing season. I do not need coil overs as the stance is how i want it. I知 looking for some adjustability for the track to help get the 60ft numbers down. I already have the BMR frame mounted rear sway bar and the car leaves well. I have added over 100 horsepower from the last time it was at the track. Any advice on front and rear shocks is appreciated. Thank you
oldsmoboogie is offline
Old December 6th, 2020, 03:35 PM
VORTECPRO's Avatar
I always run the Santhuff's.
VORTECPRO is offline
Old December 6th, 2020, 08:49 PM
chadman's Avatar
I have Afco double adjustable on the front of my 69. I recommend them.
chadman is offline
Old December 31st, 2020, 12:11 PM
w30442's Avatar
I have DA viking shocks added to my 72. Quality seems very good . I did go coil over for the front thou but its not required.
I have not been back to the track since the install, I did install a BMR anti roll bar as well.
100 hp is a nice improvement ! You need it for these heavy cars with all the furniture. I dont have the heart to lighten mine up.
All the above shocks mentioned above are good quality stuff as well.
w30442 is offline
Old December 31st, 2020, 02:48 PM
Stefano's Avatar
QA1 makes a good adjustable shock, right in the good old USA/MN.
Stefano is offline
Old December 31st, 2020, 05:58 PM
Chevy budget Olds powered
coppercutlass's Avatar
I haven't personally ran viking but that's what I'm going to next. I'm currently running the single adjustable qa1 shocks . Currently the best 60 ft. Is 1.56 but I'm adding a th350 with a trans brake and plan on going with a 4.33 should be interesting as it's back to square one. I run afco 80/20's in the front as suggested by a few racers.
coppercutlass is offline
Old December 31st, 2020, 08:26 PM
Bernhard's Avatar
https://www.summitracing.com/search/...calvert-racing
Some class racers use Calvert shocks, they are also easier on the wallet than the high end race shocks. They are not a bolt in you will have to open up the control arm a little due to the increase in shock body diameter.
I'm not saying they are in the same class of shock as some of the above listed shocks.
Bernhard is offline
Old January 2nd, 2021, 08:52 AM
I heard the rear calvert adjustables are pretty good. I regret my single Qa1's considering I have them on the softest setting . I should have just got some 50/50's and been done with it.
Old January 2nd, 2021, 09:19 AM
Duh
Duh's Avatar
The Calvert rear adjustable shock is only a single adjust. I have not tried them yet. I do run their 90/10 in the front. They are very loose on launch but seem very stable down track. They are very good for the price.
Duh is offline
Old January 2nd, 2021, 11:56 AM
Duh for what I spent on the qa1 I wish I went with the Calverts for alot less. I run the afco 80/20 I'm the front as the front end was coming up wayyy to fast and unloading the rear.
Old January 2nd, 2021, 12:01 PM
I think I’m going with the Qa1 double adjustable shocks on all 4 corners. I have Viking double adjustable on my Trans Am and i like them but my local speed shop cant get them.
Cutlasskyle
Suspension & Handling
March 15th, 2018 09:54 AM
young olds
28
September 29th, 2015 09:31 PM
455man
29
February 3rd, 2015 05:11 PM
my71olds
October 10th, 2013 12:01 PM
BlueCalais79
March 2nd, 2013 11:45 AM
Quick Reply: Double adjustable shocks for drag racing
