2.56 rear end and axles 1962 to 1964 f/s olds/pontiac
Old January 23rd, 2020, 09:08 PM
Love1955oldsmobile's Avatar
Love1955oldsmobile is offline
Old January 24th, 2020, 03:51 AM
60193W30's Avatar
View the thread and read the comments. I was told it was out of a 64 Buick b/c it has 1" upper bushings.
Lmk if this would interest you...
https://classicoldsmobile.com/forums...ear-id-139457/
60193W30 is offline
Old January 24th, 2020, 04:16 AM
OLDSter Ralph's Avatar
[QUOTE=Love1955oldsmobile;1222784]2.56 rear end and axles 1962 to 1964 f/s olds/pontiac[/QUOTE
Did they ever manufacture them ?
OLDSter Ralph is offline
Old January 24th, 2020, 06:00 AM
The full size cars through 1964 (except for the 1964 Jetstar 88) still used the 9.3" Olds/Pontiac axle with the drop out center section.
joe_padavano is offline
Old January 24th, 2020, 06:03 AM
60193W30's Avatar
Was the 64 Buick axle the same as the Olds and Pontiac?
The one I have has 1" upper control arm bushings...
Monza verified this when he saw the pics he was sent...
60193W30 is offline
Old January 24th, 2020, 06:13 AM
Does it have a drop out center section like this?
Old January 24th, 2020, 08:50 AM
60193W30's Avatar
I do not believe so.... (center section)
Here are a couple more pics...
60193W30 is offline
Old January 24th, 2020, 11:30 AM
Thats NOT 59-64 Olds or Pontiac.
Old January 24th, 2020, 12:31 PM
rocketscientis's Avatar
64-98 conc parts car
Sold special 64 Jetstar axles to man in netherlands but still hav rest..... Hav 64 -98 convertible w/ complet differential....uncertain of ratio atm
Lansing Mi
If you think that may b usefull.. .
989 721 9432
rocketscientis is offline
Old January 25th, 2020, 11:21 PM
2.56 ratio
That's a code 2 stamped on the carrier. Only f/s olds and goats will have this ratio. This fits 57 thru 64 9.3 rear axles. I am upgrading a 57/58 rear axle.
Old January 28th, 2020, 06:49 PM
dennis_30281's Avatar
I have the whole 9.3 rearend still in my donor 62 Starfire hardtop.
send me an email
dennis_30281@yahoo.com
dennis_30281 is offline
Old January 28th, 2020, 08:57 PM
Old April 2nd, 2020, 08:58 AM
For 57/58 rear end - 2.56 code 2 ratio
Still looking for this 3rd member and axles. Or complete axle assembly. There must be one out there some where. Thanks. Ron
Old April 2nd, 2020, 11:18 AM
But of course there are
For instance th 64 jetstar &63 98 conv parts cars I posted notice here on jan 24 th may be it....if not...70 miles north of me in lansing mi is merlin melrose who used to have more than they made it looked like...
Old April 5th, 2020, 11:36 PM
9.3 inch olds/pontiac rearend 2.56 ratio
I dont think the jetstar uses the 9.3 inch rear end and the convertable is likely too heavy to have such a low ratio. I think it only occurs in basic 88 and Catilina without a/c. But i keep hoping one will surface. Ron
Old September 14th, 2020, 09:33 PM
Update. I have purchased a very nice 2.56 carrier out of a 62 pontiac. I would like to retain my 1957/1958 axles. Can i move the internal side gears inside the case to the 2.56 case? Thanks. Ron
Old September 15th, 2020, 04:32 PM
Yellowstatue's Avatar
We cut 11/16" off a '63 98 axle to fit in my '57 housing with a '62 Pontiac 2:56 gear. Still working great after eight years.
Yellowstatue is offline
Asusport
April 2nd, 2020 11:08 AM
Wedgewood Rod Shop
Drivetrain/Differentials
January 20th, 2015 08:20 AM
dhamster
March 2nd, 2014 12:42 PM
Jetstar 88
August 27th, 2011 09:53 AM
hurstoldz
September 22nd, 2009 06:33 PM
Quick Reply: 2.56 rear end and axles 1962 to 1964 f/s olds/pontiac
