Charcoal filter cannister
Old March 29th, 2010, 04:54 AM
Gary
Gary's 2 442-S's Avatar
I need a charcoal filter cannister for my 72 442. Anyone has one please let me know.
gary
Gary's 2 442-S is offline
Old March 29th, 2010, 08:40 AM
rocwal's Avatar
is this the one that recirculates the gas on the passenger side on fender ? if so I have one ,let me know and i will send you a price mail me at d.rocwal@roadrunner.com
rocwal
Dan B
rocwal is offline
Old March 29th, 2010, 08:53 AM
Lady72nRob71's Avatar
The round black vapor storage tank behind the left headlights should be the part in question.
Lady72nRob71 is offline
Old March 29th, 2010, 09:24 AM
MJAKS462's Avatar
I had one on my car and I got rid of it , but now I have that metal line with no place to plug it in , Can I just get rid of it or do I need a new canister also?
MJAKS462 is offline
Old March 29th, 2010, 12:22 PM
I would just get a new or used cannister. It plugs and vents the line and reduces fuel odor if parked inside.
Old March 29th, 2010, 12:42 PM
Cutlass Lover
cutlassgal's Avatar
So that's what that thing does, huh? Thanks Rob!
cutlassgal is offline
Old March 29th, 2010, 12:54 PM
Yep, The vapors are stored there when parked and when the car is started, the fumes are sucked into the manifold to be burned.
Old March 29th, 2010, 01:25 PM
70 cutlass s's Avatar
You can get them at the junk yard a lot of them are the same or interchange. As long as it is not crack or full of fuel then it will be fine just replace the filter before installing it into the car.
70 cutlass s is offline
Old March 29th, 2010, 05:23 PM
MJAKS462's Avatar
Ok Thanks !
I have not found a junkyard though in Minnesota that has a car older than the 80s.
Looks like ebay unless someone on here has one.
MJAKS462 is offline
Old March 30th, 2010, 12:45 AM
Seasoned beater pilot.
J-(Chicago)'s Avatar
If you're not worried about factory matching numbers, I have a pile of them from 77-85 GMs.
J-(Chicago) is offline
Old March 30th, 2010, 03:22 AM
MJAKS462's Avatar
PM sent
MJAKS462 is offline
Old March 30th, 2010, 05:00 AM
Gary
Thanks for the reply, I am getting one from ROCWALL.
Old March 30th, 2010, 11:56 AM
rocwal's Avatar
charcoal filter canister
These are available at rockauto.com for $40.00 NEW part # cp1022
rocwal
DanB
rocwal is offline
Old March 30th, 2010, 02:58 PM
MJAKS462's Avatar
I have one line coming from the gas tank for the canister but the canisters have 2 nipples on the top side Where does the 2nd hose go ? Seriously guys , get your mind out of the gutter.
MJAKS462 is offline
Old March 30th, 2010, 06:48 PM
Gary
It goes to the carburetor. if you are facing the carburetor on the right side in the front there are two lines that looks like vacuum lines built into the carburetor. the bigger one is where the hose from the cannister connects to. I am looking at an assembly manual.
Old March 31st, 2010, 03:57 AM
MJAKS462's Avatar
Ok , Thanks
MJAKS462 is offline
Old March 31st, 2010, 04:19 AM
MN71W30's Avatar
MJAKS462,
I'm pretty sure I've got a couple of those things in the shed. It would have given you a reason to stop by. I didn't see this post in time.
MN71W30 is offline
The Bug Man
November 5th, 2013 06:14 AM
Blaster
July 28th, 2013 02:53 PM
joepenoso
July 19th, 2013 12:44 PM
The Bug Man
March 19th, 2013 06:00 PM
1971 442 convert
February 17th, 2010 09:22 AM
Quick Reply: Charcoal filter cannister
