'68-9 INTAKE J-398662 or 405233
Bought another "uncracked" intake 398662
It's cracked in the usual place between the large carb bores.
While serviceable, the buyer is spending a lot for a conversion and wants perfection.
I have parts to trade, or cash.
You must have it verified uncracked. Blasted clean is best. I need it right away. Buyer wants conversion done in 4 weeks and we already burned 1 week getting the last one blasted clean only to find a crack, and the next one was clean already but also cracked.
http://www.ebay.com/itm/130971415043...84.m1439.l2649
DAMMIT
If anyone wants the red one, or parts off it- TVS, thermostat housing, CHOKE COIL, let me know, I need to recover some of that fundage. Anything.
DAMMIT
Well, if it ain't broke, don't fix it, right
I mean, it's cracked... but not unserviceable
therefore not "broke"
Welding cast iron is iffy at best. Machine shop suggested drilling a hole at the end of the crack and fitting it with a plug, to stop the crack from propagating.
No leak thru to hot air crossover. Just a crack from one side of the A/F plenum to the other.
The point is the buyer is spending a lot and expects an uncracked unrepaired part... which are getting hard to find...
anyone Should be able to spot these cracks, after magnaflux
The red intake had a crack the naked [reading glasses] eye could see; magnifying 7x loupe made it obvious.
Vertical crack, right between the larger [aft] carb bores, at the thinnest spot.
