394 exhaust manifold
Old November 9th, 2013, 11:01 AM
peteyb's Avatar
I need to find a passenger side exhaust manifold for my '63 394. Mine cracked right at the heat valve and broke off. I'll take the driver side too if you're not willing to separate a set.
Let me know if you can help.
Pete
peteyb is offline
Old November 9th, 2013, 11:54 AM
Oldskeeper's Avatar
Hi Pete,
The heat riser on a 63 394 is on the drivers side manifold and the cross over pipe wraps around and connects to the front of the passenger side manifold or you have dual exhaust and there is a blocker plate on the front of the passenger side manifold.
Where are you located?
Steve
Oldskeeper is offline
Old November 9th, 2013, 05:37 PM
peteyb's Avatar
Yep my bad. I had a different orientation in my mind. It is the driver side that I need.
I'm outside Atlanta.
peteyb is offline
Old November 9th, 2013, 08:06 PM
deaddds's Avatar
So do you have dual or single exhaust? I should have a manifold for you. Drop a line at dead@mchsi.com.
deaddds is offline
Old November 9th, 2013, 08:55 PM
Pete, if you can't find one that works you might consider having your original manifold repaired. A good welding shop should easily be able to weld cast iron.
Olds64 is online now
KQQLCAT
July 19th, 2010 09:20 AM
bjtstarfire
October 20th, 2008 03:48 PM
bbodine
December 18th, 2007 04:24 PM
jeffrey
November 26th, 2007 06:45 PM
KQQLCAT
October 29th, 2007 03:47 PM
Quick Reply: 394 exhaust manifold
