Underbody of 72 cutlass
Old March 18th, 2013, 04:45 PM
Chris
Oldssupreme's Avatar
I have refinished all the suspension parts and frame with either paint or powder, but now i am unsure of what to do under the car. There is a ton of tubber undercoating and grease. How should i remove the grease and prep and paint the underbody?
Thanks, chris
Oldssupreme is offline
Old March 18th, 2013, 08:18 PM
O's_Car's Avatar
Hey Chris, a couple years ago the TV show MuscleCar cleaned up the underbody of a Camaro they were restoring. Here's a link to what they did (skip to about 11:20 on the timeline):
http://www.powerblocktv.com/episodes...s-and-rear-end
Those guys used spray-on engine enamel on their underbody, but Eastwood sells a spray-on rubberized undercoating that you might also consider.
When my Cutlass was at the body shop they removed all that under-gunk with hand scrapers and wire wheels. It took a lot of time and elbow grease and left a big nasty mess on the floor, and they had the body on a rotisserie for easy access. We went with a custom finish - they sprayed the underbody with Line-X tinted to match the body paint color.
Just a couple ideas for you to consider.
O's_Car is offline
Old March 19th, 2013, 05:57 AM
Chris
Oskar, great, thanks very much, ill check out that link.
Chris
Old March 24th, 2013, 06:24 PM
jstrits's Avatar
I had rust free floors on a 71 I'm finishing up. someone though years ago decided to "freshin it up" with spray can undercoat. I used heat gun and scraper first. Then always use a wire knot wheel on a 4" grinder. Then I 80 grit da sanded the whole thing. etch primed, then satin black the whole thing and then duplicated the factory overspray patterns. My car had original green paint all over but the undercoating was a mess. very time consuming.barefloors3.jpg 20442/progress18.jpg[/IMG]
jstrits is offline
Old March 28th, 2013, 11:53 AM
Chris
wow, that underbody looks great! thanks to both of you for the info!
Chris
wills30
August 18th, 2014 06:28 PM
Speednut81
June 20th, 2013 01:31 PM
jeffsims
February 10th, 2013 06:34 PM
Del70
March 16th, 2012 07:11 PM
Frankenpez
February 2nd, 2009 07:03 PM
Quick Reply: Underbody of 72 cutlass
