Which shade paint
Old February 8th, 2017, 01:33 PM
denf221's Avatar
Which shade paint
Have a 72 supreme. Has anyone painted the metal radiator cover as well as the piece of metal under the cover that runs width of car in the original black? If so what shade did you use,flat,semi gloss,gloss? I painted mine with a flat black didn't turn out well. I want something that will clean up well,flat black doesn't. Also what brand paint do you think is best? What kind of primer? How many coats primer and paint? Any help would be great
denf221 is offline
Old February 8th, 2017, 01:56 PM
Rocketowner's Avatar
Smile What shade paint
I guess we would need to know what method you are using, Spray cans,spray
Gun,what type spray gun. Regardless of the answers from above ,you probably don't want "Flat black".Also tell us what are your plans for the car,daily driver, weekend local car shows,or even 100 point Show Car. Larry
Rocketowner is offline
Old February 8th, 2017, 09:16 PM
I used a Krylon semi-gloss black rattle can on mine. No primer, just hand sanded and sprayed.
Fun71 is online now
Old February 8th, 2017, 09:59 PM
Eastwood's Underhood Black would be a good choice.
1969w3155 is online now
Old February 22nd, 2017, 07:20 PM
denf221's Avatar
Thanks all
denf221 is offline
Old February 24th, 2017, 05:53 AM
rick442's Avatar
If you want gloss, I high recommend Mercuiser Phantom black. Also called Quick Silver. And if you really want it protected, use their clear coat. This stuff is great for all applications, suspension, engine, engine brackets.
rick442 is offline
JPMDaddy
January 14th, 2019 08:41 PM
rustycragars
December 25th, 2016 06:06 PM
Texas442
Paint
45
April 9th, 2015 09:21 PM
desert442
April 18th, 2008 11:24 PM
thomaswatk
March 22nd, 2007 01:31 PM
Quick Reply: Which shade paint
