To epoxy or not to epoxy
Old March 3rd, 2016, 07:19 AM
67Rocket's Avatar
Should epoxy primer or another type of primer be used over the existing paint after the paint has been thoroughly cleaned and scuffed? What do you guys think of Eastwood paint products? Appreciate it.
67Rocket is offline
Old March 3rd, 2016, 07:52 AM
Run to Rund's Avatar
I used PPG DPLF epoxy primer over some 40 year old lacquer, mostly inside the trunk. Some original red oxide primer remained on the outside, and the OEM black parts dept. paint was still on the NOS fenders.
Run to Rund is offline
Old March 3rd, 2016, 08:29 AM
jozw30's Avatar
Sealer is important especially if you have multiple materials exposed with your final prep step (400 or 600 grit wet).....
Give the color an even base and keep it all from interacting with your new finish coats.
Worth the cost and time. Buy the best materials you can afford.......
jozw30 is offline
Old March 3rd, 2016, 09:25 AM
Mr. Johnson
rjohnson442's Avatar
^Best advice right here. I've used PPG and Eastwood for years and best advise is to use a primer or sealer that will work(together) best for the final paint that you are using. Some paints and primers don't get along well and will ruin an otherwise perfect prep/spray job. If priming the entire car is out the the question. Blend the best you can panel to panel.
rjohnson442 is offline
Old March 4th, 2016, 07:50 AM
iirc the PPG DPLF has to be top coated within a week, best to do it on the same day, or it has to be sanded.
Old March 4th, 2016, 08:18 AM
jozw30's Avatar
Yeah, at that point it's really just the first coat of "paint".
jozw30 is offline
dre
Body work
29
July 31st, 2013 09:37 AM
Porter858
September 18th, 2012 08:51 PM
Seriousfun
July 27th, 2012 12:25 PM
Del70
May 8th, 2011 09:27 AM
Del70
May 6th, 2011 03:54 AM
Quick Reply: To epoxy or not to epoxy
