To epoxy or not to epoxy
Should epoxy primer or another type of primer be used over the existing paint after the paint has been thoroughly cleaned and scuffed? What do you guys think of Eastwood paint products? Appreciate it.
Sealer is important especially if you have multiple materials exposed with your final prep step (400 or 600 grit wet).....
Give the color an even base and keep it all from interacting with your new finish coats.
Worth the cost and time. Buy the best materials you can afford.......
