Other Oldsmobiles Anything not listed above, such as F-85 (1961-1963), Firenza (1982-1988), Starfire (1961-66 and 1975-80), Omega, etc.
Drive shaft bearing
Old July 21st, 2023, 02:37 PM
Jake707's Avatar
Drive shaft bearing
Anyone have a couple good pics of the stock drive shaft bearing and how it mounts to a ‘63 f85?
mine has a SBC conversion and one piece drive shaft that currently hits the floor under the rear seats when I hit bumps. So I’d like to explore going back to a two piece shaft for better clearance.
Jake707 is offline
Old July 22nd, 2023, 07:40 AM
jmcghee's Avatar
63 F85 carrier bearing
jensenracing77 is a member here. He was at least 2 threads here in the major builds section with numerous pictures of his restoation of these cars. He most likely has the parts you need also. I know that if you change your subject line to include 63 F85 you will receive a lot more answers. Good luck with your project
jmcghee is offline
Old July 22nd, 2023, 08:34 AM
Jake707's Avatar
Thanks. I found a pic in one of his major build threads. Looks like now I need to try and find or make a crossmember for the bearing to mount to
Jake707 is offline
Old July 22nd, 2023, 01:32 PM
jmcghee's Avatar
Contact Eric, he probable has the parts you need he is Jensenracing77
jmcghee is offline
Old July 22nd, 2023, 02:09 PM
jensenracing77's Avatar
On this original setup the slip yoke is in the center and not at the transmission.
jensenracing77 is offline
Chuxter
Drivetrain/Differentials
June 24th, 2023 06:56 PM
442operator
November 20th, 2022 03:04 PM
70convert
March 7th, 2019 02:12 PM
harriscu
May 15th, 2016 09:45 PM
johnnyjaws
September 4th, 2014 12:07 PM
Quick Reply: Drive shaft bearing
