Drive shaft bearing
Drive shaft bearing
Anyone have a couple good pics of the stock drive shaft bearing and how it mounts to a ‘63 f85?
mine has a SBC conversion and one piece drive shaft that currently hits the floor under the rear seats when I hit bumps. So I’d like to explore going back to a two piece shaft for better clearance.
63 F85 carrier bearing
jensenracing77 is a member here. He was at least 2 threads here in the major builds section with numerous pictures of his restoation of these cars. He most likely has the parts you need also. I know that if you change your subject line to include 63 F85 you will receive a lot more answers. Good luck with your project
70convert
Drivetrain/Differentials
March 7th, 2019 02:12 PM
johnnyjaws
September 4th, 2014 12:07 PM
