Other Oldsmobiles Anything not listed above, such as F-85 (1961-1963), Firenza (1982-1988), Starfire (1961-66 and 1975-80), Omega, etc.
61-63 cutlass rear end swap
Old June 10th, 2015, 07:52 PM
young olds's Avatar
gauging interest on making parts to swap in a different rear end. http://oldsjetfire.com/forums/topic/...rear-end-swap/ if your not a member there post in this thread
young olds is online now
Old June 11th, 2015, 10:41 AM
Good luck with this. I suspect you will find that there isn't enough interest to make it financially worthwhile. I've been looking into this. I want to keep the 4 x 4.5 bolt circle. The Ford 8" axle used in the Maverick has about the right width and the right bolt pattern. The other one I've been looking at is the 7.5 out of a 2WD S-10, which is also about the right width, but has the 5 x 4.75 bolt pattern. Both of these are leaf sprung, so welded on brackets are required. The sheet metal center section of the8" makes welding the upper control arm mounts easy. The S-10 axle has a cast center section. I haven't been able to determine if it's cast iron or cast steel, as the latter can also be welded easily.
joe_padavano is online now
350TurBRO
September 12th, 2014 11:52 AM
Beeks69
Drivetrain/Differentials
17
August 26th, 2011 04:41 AM
crank.it
April 19th, 2010 11:48 AM
olds cutlass
April 9th, 2009 05:44 PM
sscutlas
September 4th, 2007 10:20 PM
Quick Reply: 61-63 cutlass rear end swap
