how to remove fuel sending unit
Old April 19th, 2017, 06:06 AM
Sid
Sid's Avatar
I need to replace the fuel sending unit on my 67 cutlass , mine is covered with undercoat and can't see how it is removed , if anyone has replaced one let me know how to get it out.
SID
Sid is offline
Old April 19th, 2017, 06:22 AM
Sid, there is a ring that fits under a collar which retains the fuel sending unit. Use a hammer and a punch to rotate the ring and remove it. You can then remove the fuel sending unit. There is a big rubber o-ring between the fuel sending unit and the tank.
Here are some pics that should help.
Olds64 is offline
Old April 19th, 2017, 08:19 AM
Proud Viet Nam Veteran
redoldsman's Avatar
Be sure to use a brass punch or something that will not make sparks.
redoldsman is offline
Old April 22nd, 2017, 07:11 AM
Sid
Sid's Avatar
Thanks for the information , will use brass punch.
SID
Sid is offline
Old April 22nd, 2017, 07:44 AM
The ring has to rotate about half an inch to disengage.
MDchanic is offline
68RocketAction
December 18th, 2014 11:19 AM
Oldskool84
October 10th, 2014 06:21 AM
pfergy600
October 4th, 2014 05:29 PM
wikkonado
June 19th, 2010 07:28 PM
Pfiffle
February 21st, 2008 06:43 PM
Quick Reply: how to remove fuel sending unit
